Question about Garden
I have a 6010 mahindra tractor that will not start with the key. If I jump the starter it turns over but not start. I can jump the starter and turn key at the same time it will start
Big Poppa Ma
  • 302 Answers
SOURCE: won't start
Check your alternator, it may have gone bad and its draining your battery.
Posted on Dec 07, 2008
bbreton
  • 437 Answers
SOURCE: Won't start
If you don't hear a clicking sound when you turn the key, it sounds like the starter solenoid needs to be replaced.
Find your model number under the seat and go to www.precisionope.com. Look up your model there.
It may say Poulan on it but it was more like an AYP product.
Posted on Apr 17, 2010
  • 731 Answers
SOURCE: 2007 ford explorere won't start. won't try to turn
Look for the "neutral start switch " and check it ...usually on the tranmission
This switch opens the ciruit to the starter if the car isn't in Park or Neutral and if it goes bad the vehicle won't start
Posted on Jan 31, 2011
aquaman987
  • 927 Answers
SOURCE: Tractor won't turn over. Replaced Battery,
Is the engine free to rotate? Can you move it by hand? If not, the starter can't.
If so, try removing the plug and starting it.
Gary
Posted on Jul 24, 2011
  • 6468 Answers
SOURCE: I have a John Deere X300 lawn tractor with an intermittent starting problem. From time to time, when you turn the key all you get is a click. Battery is connected, headlights work, but starter will no
sounds like the contacts are dirty in the solenoid if you jumper it with a screw driver does it crank over?also check the adjustment of the clutch/safety switch
Posted on Jun 12, 2012
4530 mahindra ignition wont start tractor, but will start by jumping seilenoid to starter
Well it could be several things a safety switch for the seat, mower deck etc not in the proper position. Blown fuse,bad ignition switch, burned out solenoid. if you jump the battery side of the solenoid to the small terminal and nothing happens, it's the solenoid. If it turns over check the other items. Start with the fuse that powers the ignition switch.
Jul 28, 2016 | Garden
Won't start. Won't take a jump. There is a high pitch sound when ignition is turned on. All safety switches are good.
starter may be shot or stuck
with mower off take plugs out and rotate engine both ways 1/4 turn
then try to turn over with key, to see if starter is working
Oct 21, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Mahindra tractor willnt start solenoid will engage but starter willnt turn motor but new starter on it but the same thing solenoid will engage but starter willnt start motor
is the engine seized?
Could it be stuck in gear and is too heavy for starter to move? Working on the assumption that the gearbox/transmission is a manual type?
Jul 19, 2015 | Garden
Mahindra 3616 tractor will not start, engine will just click?
check clean conections see if jump start works could be battery solinoid or starter or wires corroded inside from battery
Jul 01, 2014 | Vehicle Parts & Accessories
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Tractor solenoid clicks but won't start
could be a safety switch or a ground problem check the ground for corrosion and make sure it is tight at all places then check each safety switch they usually have one for the seat,mower deck and clutch/brake pedal
Jun 19, 2013 | Garden
Yard king runs but ignition key to starter faulty, need to jump directly to starter
check the safety switch on the brake/clutch pedal bypass it with a paper clip to test it
May 09, 2012 | Garden
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Turn key and get a click
the started is probably jammed and needs to be unbolted and put starter bendix gear back in starting position turning over an engine too long on a jump start can cause this
Apr 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
