Question about Garden
JD175 hard to start and sometimes loses power under heavy load. (mowing) Could this be a bad coil?
    Top Expert:
  • Garden Master
  • 79,865 Answers
It sounds like a fuel starvation issue.
Posted on Apr 19, 2017
My 1969 triumph spitfire has been running fine but lately has started suddenly cutting out and losing power under heavy uphill loads. When this happens it always blows oil and smoke out aroumd the bol
time to rebuild motor or replace it. The smoke your seeing is pressure from the cylinder escaping around the piston rings into the crankcase and venting out the covers
Aug 24, 2014 | Cars & Trucks
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
My Cub Cadet 1200 lawn tractor has repeated coil failures, I change the coil, it starts and mows for a while then stops.
Hi, the problem you have is unusual. First check the plug gap as being to wide will over load the coil, also make sure your air gap on the coil legs is 8 thou. Finally remove all of the air shrouds and make sure all of the cooling fins are clean as the coils may be over heating. Regards Phil
Jun 17, 2012 | Garden
#3 and #7 misfire codes
Swapping coils between cylinders is a better solution than replacing them. This way if the misfire follows the coil you know the coil is bad. Lack of power under load usually suggest fuel starvation to me. I would change the fuel filter and then road test the car. Also if you had just filled up the tank when the misfires started, maybe you got a bad tank of gas. Sometimes right after a rain water gets churned up and gets into the pump, and consequently your fuel tank.
Dec 23, 2011 | Cars & Trucks
The blades stop turning under a heavy load on my Craftsman 42" mower deck. Is there an adjustment that can be made?
"the adjustment" is to slow down in high grass areas. alternatively mow more often so the grass does not get so high between mowings
Apr 12, 2011 | Garden
K2500 chevy 3/4 ton pick up. no power under load
IN your distributer under the rotor is a magnet and a pickup coil (the magnet is known as a pole piece) check your pickup coil for corrsion (green in color) and the module and also check pole piece for cracks in the magnet where the rivets hold it together. sometimes oil wicks up around the distributer shaft because of housing wear or the pieces just wear out over time.
May 16, 2010 | 1999 Chevrolet K2500
CH25 Kohler on a Kees mower. Back fires under light loads
you must have the throttle at full at all times when under load driving and mowing, back fire is do to much fuel. if your running throttle at full than look at the carburetor and then the wiring (short)
Oct 12, 2009 | Garden
I have a Woods Zero Turn Mow n Machine powered
Try taking the cover off to get to the fly wheel and use some fine sandpaper or emery cloth to clean off the magnets on the fly wheel and the two little prongs that set really close to the fly wheel.
My white wouldn't start right away and I did the above and now it starts great.
Let me know if that helps.
Thanks
Roundo4
Jul 31, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
