Question about Eclipse Car Audio & Video
What's the voltage output of the amp turn on from my eclipse CD 3000
2 Suggested Answers
lpfaff1
  • 11573 Answers
SOURCE: How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Posted on Mar 27, 2016
What is the watts for the cd player?
It's published rating is a measly 13 watts per channel (four channels total). That is very low for a car head unit and isn't going to drive the typical speakers this would be used with to normalr volumes without distorting. Frankly, this entry-level unit is really designed for use with external front, rear and sub amps, which is why Eclipse designed it with three sets of pre-outs. On the positive side, the line voltage level resistance on those outputs is relatively low (55 ohms), so this unit will provide a good amount of gain into a given amp.
Jan 27, 2010 | Eclipse CD3422 CD Player
Tip
Playstation2 SCPH 3000 - 5006 General Problems
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
Lens Problems (Optic)
  • Optical Spull not move (up down).
  1. Check the flexible cable.
  2. Check the Optical spull.
  3. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  4. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  5. Check the optical flexible cable socket.
  • Optics spool laterally tilted or irregular jump when the engine turn on.
  1. Check the resistor on 102 block (In IC Servo Master Control area = CXD 3098 : 470-8pin,102-8pin).
  2. Check the resistor under IC Servo Master Control.
  • Optics can only read one CD/DVD format.
  1. Check the Optic Laser Diode.
  2. Check the Optic Laser Diode with Voltmeter : V3 (CD=1080 to 1260, & DVD=800 to 1300), V4 (CD=850 to 900, & DVD=1200 to 1400), V5 (CD=1200, & DVD=1400), V7 (CD=1200, & DVD=1100 to 1400), V9 (CD=1200 to 1400, & DVD=1200 to 1400).
  • Optics Lights not lit (Lens not light).
  2. Check the optics spull.
  3. Check the SP 3727 IC.
  4. Check the Amp transistor ( in IC SP 3727 socket board), Upper for CD & under for DVD.
  5. Check the IC 7805 (IC Regulator).
  • Excellent optics but won't to read.
  1. Check the mecanic gear.
  2. If you have SCPH - 3000 series, check the IC Driver (BA 5815).
  3. If you have SCPH - 5000 series, check the IC Driver (LA 6508).
  4. Check the ModChip.
  5. Check the IC SP 3727.
  6. Check the resistor (in 220 block), between IC Servo Master Control & IC Interface (CXD 9611 BR).
  7. Check the transistor (in socket optics= pin 6).
on Sep 16, 2010 | Sony PlayStation 2 (PS2) Console
1997 eclipse has to be charged every day in order to drive
There seems to be a no charge state in this case. I recommend checking the charging system. use the procedure below to isolate this issue.
Wear protective eye wear and clothing and remove all jewelry when checking your battery and charging system. Jewelry is a good conductor of electricity and is not recommended. Most batteries wear out every 3 to 5 years and need to be replaced. Always replace your battery with an equal replacement battery to assure proper operation. Automotive batteries have a +positive terminal (red), - negative terminal (black). Electricity is stored in the battery and then supplied to the vehicle when the engine is not running. While the engine is running the vehicles alternator charges the battery for future use. (Note: never disconnect the battery while the engine is running. If the battery cable is disconnected from the battery a spark can be generated which can cause the battery to explode or a major electrical malfunction to occur.)
To check a battery surface voltage, remove the positive terminal protective cover. Connect the +positive side meter lead (red) to the positive side battery terminal. Connect the - negative (black) side meter lead to the negative battery terminal. With the vehicle not running and the car sitting over night the battery voltage should be between 12.5 and 12.8 volts.(You will need to use a voltmeter for this testing procedure)
The alternator is rotated by a drive belt driven by the vehicles engine while it is running. Electrical voltage and amperage are generated to recharge the battery and supply voltage to the electrical system of the car. The alternator is held in place with mounting bolts. There is a main electrical wire on the rear of the alternator that supplies voltage to a main voltage junction box. If your alternator is not charging properly, your battery will slowly drain down from operating all the electrical systems in your car and stop the car from running.(most non charge states will be the cause of a loose belt or a low tension rate, due to a mis-adjusted alternator. make sure you have enough tension in the belt for full rotation of the alt pulley)
Next, you will need to check the alternators output with the Amp meter.
Testing the amperage output of the alternator is good for measuring the amount (not the level) of voltage the alternator can produce. This test can be tricky because if the alternator is weak it can still show it as producing amperage. Which is good, but if the voltage is low, it will still allow the battery to go dead. To check the amperage output of an alternator an amp meter is needed. Once the meter is connected start the engine. Next turn on all electrical accessories and raise the engine idle to about 1200 RPM. The alternator should output the max amperage it was designed to produce. Example: a 90 amp alternator should output about 88 amps. Note: An alternator cannot sustain maximum output for long periods of time. If the alternator is forced to operate at maximum output it will overheat and fail. An alternator is designed to operate at max amperage output only for a reasonable amount of time.
((Connect the voltage meter lead the same way you would in a battery static voltage check, Start engine (do not drive) at engine idle the voltage should be between 13.6 to 14.3 volts. If not the alternator may need replacing.)))
Dec 22, 2009 | 1997 Mitsubishi Eclipse
Eclipse wont start .
starter relay or maybe your starter does it turn over?
Jun 11, 2009 | 2000 Mitsubishi Eclipse
1996 honda VT1100c2 backfiring & missing when accelerating
Replace Fuel Filter.
Test fuel pump output.
Remove and service carburetors.
Jun 07, 2009 | 2005 Honda VT 1100 C2 Shadow Sabre
I am working on a wurlitzer model 3000 amplifier model 546b the audio is distorted and the voltage seems to be floating on the output transtors when I turn up the volume the power on the outputs drops ...
They are actually lamps used as a current limiter. If that helps.(?) They have low resistance for a fraction of a second.
I can't be more helpful than that but that's what they do. You can get them from Radio Spares and they have a particular name. You could try The Jukebox Man (UK). He is an amp specialist and will at least know what you are referring to.
Dave F.
Nov 11, 2008 | Wurlitzer Jukebox 1015 One More Time...
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
Jun 20, 2008 | Eclipse EA3422 Car Audio Amplifier
Eclipse 2.13oe camtec
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 13, 2008 | Eclipse EA3422 Car Audio Amplifier
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Car Audio & Video Logo
22 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
