Question about In Office Equipment & Supplies
What if no paper is in it and i power it up - In Office Equipment & Supplies
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Check paper light is blinking. No paper jam exists, have cleaned rollers but printer will not grab paper. Have tried replacing with fresh paper but no result. Will not print test page, gives same error.
Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
1) Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
2) Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you.
NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
3) From the rear access door opening, gently pull the jammed paper free.
4) Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
5) Reattach the rear access door by inserting the two pins on the right of the door into the holes for them and then pressing in gently but firmly on the left side.
6) Reconnect the power cord to the unit and turn the unit on.
7) if it does not work ... clean the rollers from the rear door of the printer
8) try different wall outlets..
9) then do a power drain by unplugging the power chord from the back of the printer. press and hold the power button for 30 sec and then replug the power chord.
10)if issue does not get resolved service the product
Mar 26, 2011 | HP PSC 1401 All-In-One Printer
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2ΒΌ-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
Paper jammed under carriage....how do I get to the paper to help remove it, besides lifting top.....how do you get underneath?
From HP: Clear paper jam
  1. Turn off the all-in-One and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the All-in-One. The power cord must be disconnected to remove all power from the All-in-One. The paper feed rollers would not turn freely until all power is removed.
  3. Turn the dial on the rear access door to the unlocked position and remove it.
    Inspect the rollers on the rear access door and make sure that they are clean and turn freely. If necessary, clean the rollers with a soft towel lightly moistened with water
  4. Gently pull the jammed paper from the back of the All-in-One.
  5. Reinstall the rear access door after removing the jammed paper. Turn the locking dial clockwise as far as possible to securely lock the door or paper skewing may occur.
  6. Remove all the paper from the paper supply tray and inspect it for damaged edges. Remove any paper that is not in a good condition. If the paper has already been printed on once, replace it with fresh paper. Even up the stack of paper and reinsert it.
  7. Reconnect the power cord and turn on the All-in-One
Aug 17, 2009 | HP PSC 950 All-In-One InkJet Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Says have paper jam when there is no paper in the printer
see what you gotta understand
is that right next to the
rollers that pick up the paper
are paper sensors so if those
sensors have been damaged take
a cotton swab dip it in water.
clean the rollers where the
paper is taken in from and
also clean the carriage rod
along which ur cartridges
move(metallic rod).
Remove any loose paper from the input tray. Press the Power button (c01345237.gif ) to turn off the product.Disconnect the power cord from the back of the product.
  1. Gently pull any jammed paper out of the rollers in the back of the product.
  2. Rotate the rollers upward to make sure that they move.
  3. Clear any paper jammed paper from inside the duplexer.
    1. With the wheels facing toward you, unlock the duplexer by pulling back the gray levers on each end of the duplexer.
    2. Open the duplexer lid.
    3. Remove any paper from inside the duplexer.
    4. Close the duplexer lid.
    5. Lock the duplexer by pushing the gray levers up and forward until they snap into place.
Before reattaching the duplexer to the back of the product, follow these steps to clean the paper rollers to remove any debris, dirt, or paper scraps.
  1. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward with your fingers to clean all the way around.
  2. Allow the rollers to dry completely.
  3. Reattach the duplexer to the back of the product. Gently push the duplexer forward until it snaps into place.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
  6. Load paper in the paper tray.
  7. Try the print job again.
    • If the error message displays again, proceed to the next step.
    • If the pages print successfully, you do not need to continue troubleshooting.
Follow these steps to clear the jam from the automatic document feeder (ADF).Remove all originals from the document feeder tray.
  1. Lift the cover of the ADF.
  2. Lift the ADF mechanism.
  3. Gently pull the paper out of the ADF mechanism.
  4. Lower the ADF mechanism.
  5. Close the ADF cover. Press down until the cover snaps into place.P
  1. ull out the main input tray.
  2. Slide the paper-width and paper-length guides to their outermost positions.Insert a stack of paper into the main input tray with the short edge forward and the print side down. Slide the stack forward until it stops.
  3. Slide the paper-width and paper-length guides inward until they stop at the edges of the paper.
  4. Push the main input tray back into the product.
  5. Pull the output tray extender towards you, as far as it will go
  1. Press the Power button (c01346625.gif ) to turn the product off.
  2. Disconnect the power cord and the USB cable from the product.
  3. Unplug the power cord from the wall outlet.
  4. Reconnect the power cord and the USB cable to the product.
  5. Plug the power cord back into the wall outlet.
  6. Press the Power button (c01346625.gif ) to turn the product on.
Jun 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper jam
Solution
Step one: Remove any lose paperRemove any lose paper from the paper tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the product
  1. Remove the paper from the paper tray.
  2. Press the power button (c00636182.gif ) to turn off the product.
  3. Disconnect the product power cord from the electrical outlet.
  4. Remove the rear access door. Press the handle to the right, and then pull out the door.
  5. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  6. Replace the rear access door.
  7. Load paper in the paper tray.
  8. Reconnect the product power cord to the electrical outlet.
  9. Press the power button (c00636182.gif ) to turn on the product.
  10. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step three: Open the top cover and clear the jamIf the paper jam cannot be removed from the back of the product, try to remove it from the front.
  4. Raise the product cover, remove the paper jam from the front of the product, and then lower the cover. CAUTION: Remove the paper jam carefully because it is possible to damage the printer when removing paper from the front.
  5. Load paper in the paper tray.
  6. Reconnect the product power cord to the electrical outlet.
  7. Press the power button (c00636182.gif ) to turn on the product.
  8. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step four: Make sure that the carriage can move freely
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Raise the cover and try to move the carriage from side to side by hand. 1 - Carriage holding ink cartridges
  4. If the carriage does not move, the product needs to be serviced. If the carriage does move, proceed to the next step.
  5. Make sure that the ink cartridges are locked into the carriage and have not come loose. Make sure that there are no obstructions under or around the carriage to prevent it from moving.
  6. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and to the right.
  7. Close the product cover and reconnect the power cord to the back of the product.
  8. Press the power button (c00636182.gif ) to turn the product on.
  9. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Oct 22, 2008 | HP Office Equipment & Supplies
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
