Question about Hitachi Saws
Hitachi c12lch guard does not stay in place. I replaced the screw and washers however the slot in the guard arm does not lock and slides in the slot no matter how tight it gets
  • 1462 Answers
SOURCE: I replaced the spray arm seal, but the arm still wont spin.
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Posted on Apr 08, 2007
  • 33 Answers
SOURCE: Tone Arm
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Posted on Aug 14, 2008
  • 5 Answers
SOURCE: how do I attached mattress spring to crib base
The above picture is how our Jardine Enterprises crib attaches the mattress support to the frame. I am thinking you need the bolts to make your crib work. And that might be a chore unless you are very handy with hardware. Also, being a new parent ourselves, I would recommend against anything but the safest crib for your child. Call the original owner--see if they can find the bolts/hardware, if not get a complete unit if you can afford it, it may cost more in the short run, but may save a serious injury or worse. Also, if you go the used route see if it has been recalled, you can start here:
http://www.thenewparentsguide.com/choosing-a-baby-crib.htm
Posted on Jun 05, 2009
  • 3600 Answers
SOURCE: the foward and reverse button/slide does not lock
The locking ball spring is bad, you can remove the spring and stretch it to add tension to the spring so that the ball locks the trigger assembly in place. If you need more help post here and here is a web page for parts and books with diagrams.
http://www.toolmedic.com/Schematics/ChicagoPneumatic.aspx
Posted on Sep 10, 2009
  • 972 Answers
SOURCE: 94 Astrovan freon leak
most switches ive seen have a o ring
Posted on Apr 03, 2010
Elu 172. How do I remove flip top and the safety guard to clean?
Hi mate this is in the wrong category but i have an elu flip saw and to remove the guard you take your blade off and guide bush and remove the circlip and the guard pops off but u need to make notes on where the guard return spring fits through a hole on guard so as to replace, and remove the bolt with the screw driver slot in and washer / spacer to detatch the folding arm inside the guard, i will check mine and jog my memory then get back to u,does yours have a duel size bush for different blade diameters / centres. Paul
Sep 19, 2015 | Garden
How do I change the belt on a dirt devil dynamite II cyclonic
Hi! Happy to help with that. Please follow the steps below.
  • Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the three (3) screws.
  • Lift and remove brushroll. Dispose of old belt.
  • Slide belt onto motor shaft.
  • Place new belt in area of brushroll without bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end cap on the left is in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
  • Reattach nozzle guard by carefully sliding back into place. Interlock rollers and nozzle guard by tilting rollers down towards the base while replacing the nozzle guard.
  • Be sure to replace all three (3) screws.
Hope this helps!
Oct 12, 2014 | Dirt Devil Vacuums
I want to see a pictute of the bottom of the vacum cause is not working
Hello! If the brushes are not spinning your belt may be broken or stretched out. I have included steps to checking and replacing your belt. There is also a link to the owner's manual attached that shows you illustrations on how to change the belt.
  • Lay the cleaner flat and flip it to expose the nozzle base. Remove the 5 screws.
  • Pull and lift the nozzle guard off.
  • Inspect the belt for damages. (nicks, cuts, broken, stretched)
  • Replace the belt with a Dirt Devil style 15 belt.
  • Slide new belt onto motor-shaft.
  • Place belt on area of brushroll with no bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation.
  • Reattach nozzle guard.
  • Secure by aligning the 3 tabs in the base slots.
  • Replace all 5 screws.
http://dirtdevil.com/file/956/
Hope this helps!
Oct 06, 2014 | Dirt Devil Easy Lite Quick Vacuum
How do i change the belt on the dirt devil vacume cleaner
Hi there! Below are steps to replacing the belt on your vacuum. I have also included a link to the instruction manual which has illustrations if needed.
1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips screwdriver to remove the four (4) screws. Arrows show location of screws.
2. Lift nozzle guard off.
3. Slide belt off motor shaft.
4. Lift and remove brushroll. Dispose of old belt.
5. Place new belt in area of brushroll without bristles.
6. Slide belt onto motorshaft.
7. With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is properly aligned.
8. Reattach nozzle guard.
9. Secure by aligning the three (3) tabs in the base slots. Be sure to replace all four (4) screws.
http://bit.ly/1s8GQSX
Hope this helps!
Jul 27, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Need to know how to get the blade off the miter saw to replace the blade
First, make sure it's unplugged.
On many saws the guard mechanism partially covers the bolt that holds the blade in place. Loosen and move the part out of the way as recommended by the manufacturer. On this saw you loosen a screw and then slide the mechanism up and towards the rear.
Press the spindle lock to lock the blade in place. Turn the bolt clockwise - opposite the normal direction - to loosen and remove it. Remove the outer blade washer and the blade. Leave the inner blade washer in place. Wipe a drop of oil on the surfaces of the blade washers that touch the blade.
Put the blade on the saw so that the teeth point down. Putting the blade on with the teeth facing in the other direction can result in serious injury. Put the outer blade washer in place. Turn the bolt counterclockwise until it is snug, plus another 1/8 to 1/4 turn. Replace the cover and you're finished.
Oct 27, 2011 | Saws
I was trying to fix the door lock problem myself on my Whirlpool Duet Washer GHW9150PWO and I pushed the door lock mechanism down with a screw driver and it locked into place. Of course the door won't...
Did the screw driver make it out? UNPLUG THE WASHER There are 2 screws at the top of the washer that hold the top cover on. remove the screws and SLIDE the top cover back off the washer. This should expose the door lock assembly, down the right side of the door. There is 1 or 2 screws that need removed and then there is enough wiring that you should be able to pulll the switch where you can work on it.
Now here's the hard part. What probably happened was that the actuator was popped out of its cradle, possibly losing its spring tension. There are clips on on half of the plastic covers(2 halves snapped together). VERY carefully separate the assembly watching for a loose or shooting spring popping out of the covers. If the spring is still on the acauator arm, and hooked in place, good. carefully put the arm back in its cradle. hopefully it snaps in so reassembly is MUCH easier. Simply snap th e assembly back to gether. test the arm with your screw driver to make sure it is springy. Re install the lock where you removed it from the door area. Good Luck.
Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Front wiper motor not working
disconnect the negative battery post.
disconnect the harness from the wipper motor, using a 8mm socket, loosen the two crank arm socket screws and lock-washers until the socket releasesfrom the crank arm ball. do not remove the crank arm from the motor.
using a 10mm socket, remove the three motor retaining screws, slide the motor out of the slot in the bracket.
To install make sure the wipers are in the park position, slide the motor into the slot in the bracket. using the 10mm socket, install the three motor retaining screws and tighten to 49-80inch lbs.Using the 8mm socket tighten the two crank arm socket srews and lock washers. connect the harness to the wiper motor.connect the negative battery cable
Jan 23, 2009 | 2003 Chevrolet Venture Passanger
How do you chabge the belt in the dirt devil ultra swivel?
Attached is a copy of the link for the manual. I have included the steps here, but the manual has drawings on page 10 of the manual, it will tell you how to change the belt. You will need a phillips screwdriver.
  1. Lay cleaner flat and flip cleaner to expose nozzle base. Base should lay flat end face up. To remove nozzle guard, use Phillips or Flat head screwdriver to remove the 5 screws. Arrows on diagram shows locations of screws.
  2. Lift nozzle gueard off.
  3. Be sure belt is off motor shaft. Lift and remove brushroll. Dispose of old belt.
  4. To Replace belt, Slide belt onto motorshaft
  6. With new belt in place, pull end slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation. Rotate brushroll manually to make sure belt is prperly aligned.
  7. Reattach nozzle guard
  8. Secure by aligning the 3 tabs in the base slots. Replace all 5 screws to secure nozzle guard.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=23331
Please rate this solution
Jul 31, 2008 | Dirt Devil Vacuums
Saws Logo
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
