Question about Garden
Ts420 chop saw fuel in crankcase and exhaust E
    Top Expert:
  • Garden Master
  • 78,267 Answers
Hole in the piston or a badly scoured cylinder wall or broken rings
Posted on Apr 19, 2017
Still ts420 concrete saw fuel line placement?
its a stihl chainsaw motor adapted into a concrete saw
Stihl Ts420 Parts
shoudnt have to take too much apart
take off air filter cover to see the carby
Apr 30, 2017 | Garden
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Ts400 hard starting
Check the fuel tank vent, it could be creating a vapour lock in the fuel tank
Nov 05, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
Husky 254.wont start.fuel is filling up the carb.running out the exhaust,has spark,new fuel filter,it wont fire not even a splutter
i dont know ,usually when cylinder fills up with gas ,the float seat and needle needs to be changed. but this is a 2 cycle chain saw and not a 4 cycle lawnmower. and it is 2 cycle which means that the air/ fuel mixture goes into the crankcase first, before getting to the cylinder. So you are saying to me that your crankcase is full of 2cycle fuel, youe cylinder is full of 2 cycle fuel and the exhaust is full of 2cycle fuel.
TIME FOR a new carburator
or at the very least,a carb rebuild kit
If you want to do the job just once and be sure it will be fixed,
buy the new carburatior, but a new carb is at least $46.00 plus tax and 7.00 to 12.95 shipping. and that price is for a 33cc homelite ranger,14 inch saw, which I might just sell for parts because it is a solid body,not anti vibration handle.
so ,is your husky worth spending slightly under $100.00 on
if not ,try rebuilding the carb, may only cost 20.00 to 30 for parts but might not work & be a complete waste of $
Im not fimiliar with husky prices, I know they are big cc, heavy wieght and big price. Every thing I dont want in a saw
I can get a referbished homelite 16 inch 38 cc with anti-vibration handle for 78.00 & 7.00 ship with 90 day warranty.
or brand new for $110.00 amazon.com if you run it at 30:1 oil ratio, it will last forever or until the carb craps out,which ever occurs first.
Oct 07, 2013 | Homelite Garden
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
Stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Jun 22, 2012 | Saws
My Brand new Stihl ts420 cut saw wont run full throtle, smokes white, and leaks fuel out of exhaust filter. it runs like the choke is half on.
This sounds like the carb is flooding, there is a rubber tipped needle under the metering side of the carb, this may be leaking, before replacing the needle make sure the air filter is not blocked, replace with a new filter and try again
Dec 14, 2011 | Stihl Ts 410 420 Cut Off Saw...
Husqvarna 357xp flooding
2 things you might want to look at.
1) Vacuum test your fuel line. This is a common problem with huskys.
2) Check to see if the exhaust port or spark arrestor screen is plugged up. If so pick out a carbon deposits.
Apr 09, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
