Question about Golf
Ezgo electric cart will not go in reverse - Golf
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
It depends on how old. Older modelsister use to have large copper contacts if they are worn down you should be able to replace them. Make sure you check on the selector you replace all springs
Posted on Apr 19, 2017
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
Aug 02, 2017 | Golf
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 | Golf
Troubleshooting a golf cart - > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix - > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Apr 09, 2010 | 1993 Acura Vigor
Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
Jul 17, 2009 | 1995 Volkswagen Golf
Golf Logo
478 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
