Question about Ovens
Had my oven on heat n hold then after several hours it went off and now i cant get clock to come back on i can set it but it last short time the stops
    Top Expert:
  • Ovens Master
  • 77,932 Answers
Sounds like the control panel has failed.
Posted on Apr 19, 2017
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
oven can be changed from Fahrenheit (°F) temperature to Celsius
Oct 26, 2012 | Wolf Range Ovens
Ovens won't heat
Have you set the clock alot of ovens need the clock set so the oven will work, this is a safety thing so if you set the oven to turn off after 1 hour or at a certain time of day and say the power went out or the gas was turned off and came back on then the oven won't just start up on its own
Mar 08, 2011 | GE Monogram® ZET958 Electric Double...
In trying to update to daylight savings time, I forgot how to set the clock.
Hi- Press and hold clock button until clock flashes. Set the time up or down. We already lost an hour and have to wait till fall to get it back,- don't lose any more time on this! Let me know if this helps- Thanks- Ed
Mar 15, 2010 | Whirlpool RBD245PRS Stainless Steel Oven
How do I set clock on Belling Synergie Multi-funtion oven (xou270)?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Jan 30, 2010 | Belling XOU252 Electric Single Oven
How do you set clock on hotpoint bu62 double oven
electronic clock I presume. first of all turn power off then back on. Clock display will now be flashing.
press and hold the two buttons far left and hold in. at the same time press the + or - button to set clock. You should also have a pan icon between the hours and minutes iluminated which means you are in manual mode
Oct 21, 2009 | Ovens
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
I have a whirlpool RBS245PDQ12
you probably have the clock set wrong and oven is on automatic.switch off for 5 mins, get your book out and reset the clock
Jul 06, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
