How to take the top off to put water in the basin!
Why will the motor on my rainbow power on if I hold it up off of the water basin and push the safety switch with a screwdriver but when it's sitting on the water basin it won't power on ?
There is a little tab that sticks up on the water basin, this tab pushes in on the switch allowing the unit to run, I'm guessing the little tab on the tank is broken off.
Feb 06, 2016 | Rainbow Vacuums
Stuck pfister faucet sleeve
  2. Thanks to Danny Paccho I purchased a wrench to use in removing the sleeve from Geers Plumbing
  3. Then , removed the \'87 Price Pfister faucet housing from the basin by disconnecting the 2 pipes under the basin and removing the top basin nut; inserted the wrench into the top, turning counter-clockwise until it locked (er tightened a bit) and hammered it out ,gently?, to not damage the escutcheon threads , or the basin nut.
Feb 19, 2013 | Price Pfister Plumbing
Water is draing to the bottom catch basin in my Frigidaire Model FRT18B4A refrigerator. Under the 2 bottom drawers there is a catch basin. It takes a week to fill with water. I spounge it out before...
The source of that water is from the automatic defrost cycle in the freezer,the water is supposed to run through a drain in the freezer but that drain is blocked so the water is draining into the refrigerator vents and ultimately to the catch basin instead of draining .
This tip i wrote will help ya to clear that drain in the freezer http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 16, 2011 | Frigidaire FRT18B4A Top Freezer...
The cannister begins to shake during usage
Either you have too much water in it, or your water separator is missing teeth. The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use a your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Never store your Rainbow canister on your water basin.
You fill the water basin to the top of the knub thing that is inside of it.
If it is a standard water basin, it holds two quarts, of water. If it is the larger one, it holds 4 quarts of water.
If your vacuum begins shaking or swaying during usage, that meens that you need to poor out the dirty water, and start over with fresh water, because the water level will rise as it gets dirtiet.
If you have any more questions, let me know.
I am a Rainbow vacuum expert.
Thank you,
Ralph
May 26, 2010 | Rainbow 75th Anniversary Canister Vacuum
Water coming out of the metal plate on top of the machine. Worked perfect until then. Thanks
Remove the top panel, then remove the water basin check to make sure the hole leading into the tank from the basin is not blocked.
Mar 10, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Leaks water from the top resevoire
Either your fill tank is clogged, or your washer seal is cracked. You will need to remove the top of your Bunn to access this area. In the resevoir you will see a large nut with a drain hole. First try clearing the hole with a tooth pick and pour water in the basin. If it flows you have good drainage. Now, with the top still removed, pour water in the basin while checking for leaks. If a leak is present you should remove your drain nut and inspect the clear white looking washer on the underside. If it is cracked you can replace it with a gasket from Bunn. If you are tight on time and cash, a non rubber heat proof water hose gasket will suffice until yours arrives from Bunn. Replace and re-tighten the basin and drain nut (do not over tighten) .
Feb 01, 2010 | Bunn VPR Coffee Maker
How much water to put in rainbow rainbow and should it blow out air
Fill the water in the basin to the top of the peg in the middle of the basin. (a little over an inch in the 2 quart basin) The Rainbow blows out air just like any other vacuum cleaner does throught the exhaust port. It will blow out there while the vacuum is running if the exhaust port cover is missing. Otherwise, with cover in place, it will blow out air all around the mid section of the canister while it is running.
Jun 21, 2009 | Rainbow Rainmate Air Purifier
Pegasus Push Button Drain leaks when you push the button
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Mar 09, 2009 | Plumbing
Top Rack not cleaning
If you have the model with a garbage disposal, more than likely the chopper assembly broke. It's a fairly straight forward fix. Sears part# 8268383.
Oct 22, 2008 | Kenmore 15129 Built-in Dishwasher
Hotpoint WT540
FIRST YOU WOULD HAVE TO PLUG THE MAINS PLUG OUT THEN TURN OFF THE WATER AT THE RED AND BLUE VALVES THEN TAKE OUT THE DRAIN HOSE AND PUT IT IN A BASIN MAKE SURE YOU PUT THE HOSE INTO THE BASIN ON TOP OF THE MACHINE THAN SLOWLY BRING THE TWO DOWN TO THE FLOOR MAKE SURE THAT IT IS FULLY EMPTYED OF WATER THAN LOOK AT CENTRE OF THE DRUM AND YOU SHOULD SEE A LARGE BLACK HOSE WITH A CIRLCLIP FACING AT YOU RELEASE THE SCREW UNTIL YOU HAVE THE CRILCLIP OFF THAN HOLD THE HOSE AND PULL OUT THE PLASTIC FILTER JUST CLEAN IT OUT AND PUT IT BACK IN REVERSE ORDER AS I HAVE WRITEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
