Question about Yamaha Audio Players & Recorders
What amp fuse shouldd be used in the plug of a yamaha stagepas 300 pa
4 Suggested Answers
  • 22 Answers
SOURCE: I have a Yamaha Stagepas 300, and the mixer has
The stagepas 300 has two fans. Both of them are known to go bad. you can order the two fans from yamaha, but they are very pricey for what they are. (unless your service tech like me :-)) The part numbers are AAX62021 and AAX62041.
Posted on Apr 16, 2010
caroldon
  • 17130 Answers
SOURCE: Shure SM58 A singer has joined me with her own
Please get the microphones checked seperately If there is an impedance difference orr if the coil is damaged then this difference of sound is possible.
So just check it out or else replace the mic.
Posted on Sep 13, 2010
  • 811 Answers
SOURCE: I own a Yamaha Stagepas
Contact for assistance by dialing (888) 892-6242 Monday through Friday, from 7:30AM to 5:00PM Pacific Time (closed 12:00PM to 1:00PM). You can contact them at that number ask them for the replacement fan for your component. I tried to find the actual parts if you were to go ahead and pull the bad fan out you can just take it in to a local computer shop most likely the fan is a basic fan make sure the voltage and the size is the same before installing I would do this to save money and time. Check it out anyway to see if you can find a fan locally. Bestbuy has all that stuff if you have one in your area take it to them or a local computer repair place. As you know do not continue to run the unit without the cooling fans working otherwise you will end up with a burnt system. Thanks for using FixYa! John
Posted on Feb 20, 2011
Stagepas 300.Why does one of the mic volume controls, have to be at full level to hear anything through the speakers the others are OK ?
I would suspect the input jack on that channel is either bad or has a leg come loose from the circuit board.
Jun 04, 2016 | Yamaha STAGEPAS 300 PA System
Stage pass300 cuts out during my gig
Normally that would indicate a problem with the power supply section of the amplifier.
Mar 16, 2015 | Yamaha STAGEPAS 300 PA System
Why does it cut out during a gig
Generally that indicates a power supply problem.
Yamaha Stagepas 300
short.. main out mosfets are damaged.
Sep 09, 2014 | Yamaha STAGEPAS 300 Portable PA System...
I have a yamaha stagepas 300 system. When I connected up the mixer to the power cord and switched on white smoke came from the air vent. What is this?
Well, if the system does turns on, it could be just an OPAMP its one of various little 8-pin ic's that are in the pre-amp section that got fried, STAGEPASS YAMAHA Powered mixers runs with a switchmode power supply, if the power amp section has any problem the power supply does not turn on, if you can add further details like if it does turn on, the green light turns on, do you hear something in the speakers, the more the info the best i can help you.
Paul.
Nov 04, 2013 | Yamaha HD-200 / StagePas 300 Package
How can I obtain a plugin 100w module for my Stagepas 300 as both output transistors are short circuit plus several pcb mounted driver transistors/resistors damaged.Thank you David Bunn
You could try buying the part from Yamaha America... the music section in California. Transistors and resistors are easily replaceable so repair of the board would be the path I would take myself... but then I am an electrical engineer.
Aug 24, 2011 | Yamaha HD-200 / StagePas 300 Package
Shure SM58 A singer has joined me with her own SM58 ,i have to turn the volume up much higher on mine ,with a more muffled sound .This is causing a prob .The PA is a Yamaha Stagepas 300
Sep 13, 2010 | Shure SM58 Professional Microphone
For Tascam DP02 can't record and listen
Assuming your PA is a Yamaha STAGEPAS (although I thought 500 watts per side was the biggest one you could get). Anyway, on your PA's panel you will have the karaoke machine(s) plugged into the CD ins (top of the panel), while closer to the bottom you'll see the 'monitor outs' L and R 1/4 inch jacks. These are where you'd run the L and R from the PA into your Tascam (or L alone for mono out). The monitor outs are line level and are good for independently powered speakers, recording equipment, mixers etc. Just avoid using any outputs labelled 'speakers'.
bd.
Oct 25, 2008 | Tascam DP01 All-In-One Recording Package...
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
