Question about Kitchen Ranges
My gas stove knob wont come off of the stem - Kitchen Ranges
    Top Expert:
  • 12,744 Answers
Need to pry off food /crud/rust can act like a glue
Posted on Apr 19, 2017
How to adjust the flame on a gas cook stove model is 790.3693
Set screw inside control know. Pull knob off and adjust the tiny set screw while the burners on lowest setting. Ensure the knob stem does not turn while you adjust screw. Fraction of a movement
Dec 28, 2017 | Kitchen Ranges
Gas won't stay on when I release knob
The old easy to work on and gain access to all the parts, etc. On the newer stoves, you'll have to get to where the knob goes onto the gas stem, and behind it----where the stem connects to the actual gas line inside the stove.. If you can do that, fine. Then, clean the stem, especially the nozzle. Check to see if it works before putting everything back together. If that doesn't solve it, you'll have to take the nozzle off and inspect the gas line that connects to the nozzle. Clear any gunk away, and do the same with the interior of the nozzle.........then reconnect, and test. If that doesn't solve the problem, you'll have to call a tech to come out.
Dec 08, 2015 | Kitchen Ranges
How do I replace burner knob on panel?
Most hardware stores like Home Depot and others, have parts for gas stoves.
Hope this helps.
Mar 29, 2015 | Kitchen Ranges
How do I fix the broken oven knob on my GE XL44 oven?
First you need to check the value body (around the value stem) for leaks.. you can use soapy water, your nose for smell...if you suspect a gas leak... turn the gas off to the appliance (located behind the stove) and call your gas supplier or a service tech...
You can use a thin pair of needle nose plyers to hold the stem.. or an easier way is to cut a playing card in half, poke a hole in the middle of it so it will slide over the stem... cut a line for the edge of the card to the hole so you'll be able to pull the card out from under the installed knob...
Jun 21, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
The knob on my stove top burner wont turn
Hello- If it is a gas range it sounds like the valve is stuck, they can get gummed-up and corroded over time. If you are willing to have a repair person out they should be able to take it apart and free-up the valve stem without replacing the valve itself. I would not use that burner, or try to force it ON because if the valve stem breaks you could get a gas leak, if it is gas. If the range is electric you will need to have a new switch installed. When you call for service tell them the model number of the range so they can have the correct switch on hand. Hope this helps, best regards.
Sep 28, 2010 | Electrolux 30" Self-Cleaning Freestanding...
I have an stainless LG gas range and the knobs are loose and crinkled. LG will not replace them even though it is within the 1 year warranty period. They want to sell me a set for several hundred dollars....
I have the same problem. I have gone thru 2 sets of knobs for my LG Gas Stove. Even when I put JB Weld inside the knob to hold it together the knobs only last for 7-8 months of use. I am looking for a universal know with the same stem configuration to slip onto the shaft of the LG stove. It looks like a D
Jun 11, 2010 | LG LRG30855ST Stainless Steel Gas Range
On my Caloric gas stove Model RSK 3700 UWW, a control knob has broken off leaving about half of its stem (or tongue) tightly lodged in the stove's female control- knob socket. How can I extract this broken...
Unfortunately you can't remove or replace these buttons, no parts seem to be available anymore. Keep a match stick handy to stick in the hole and press the leftover bit.
May 09, 2010 | Jenn-Air JGR8855BDS Gas Kitchen Range
Good advise on removing the knob. My problem is that the Valve stem has excessive play in it. How do I replace valve stem.
Hi, the valve stem on a gas stove is on a manifold assembly under the top. If I am correct in remembering, the burner valve unscrews to replace them. If so, take it with you along with all of the numbers,M#, S #, and so on. Best of Luck,
Nov 23, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
