Question about Car Audio & Video
Need help connecting my 02 sensor. Wires dont match up and cant figure out which is which. The new sensor has 2 white a black and a grey.wires on truck are black, brown ,white w/red and white w/green.
  • 2,433 Answers
Just switch them around. It will run rough if its not rite.
Posted on Apr 19, 2017
  • 2 more comments
  • Michael Beaver
    Michael Beaver Apr 19, 2017
    Ive tried doin that but i cant even get it to start
  • Bill George
    Bill George Apr 19, 2017
    It should start weather it has a good or bad one or none at all. I would say you have another problem. Start from the beginning of what happened to get to this point. Did it just die as you were driving or just wont start. Remember you need spark,fuel and air for it to run.
  • Michael Beaver
    Michael Beaver Apr 20, 2017
    It started just fine before and is my daily driver. I put the new one in and it started and ran and then died and hasnt started since. Turns over but wont start
  • Bill George
    Bill George Apr 20, 2017
    What, engine.year.model.auto/stick.4x4 is this vehiclePull a plug out and see if it has spark.if there is a fuel rail for injectors put a guage on it should be around 40psi.
  • 351 Answers
SOURCE: hoover 710 top load washer
They sound
Posted on Mar 02, 2008
m-sykes
  • 71 Answers
SOURCE: oxygen sensor on a 93 civic dx
the sensor you got is for the 1997 model
Posted on Aug 22, 2008
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
szanti
  • 36 Answers
SOURCE: Security Camera
it is important to know model and make or camera if you want a solution
Posted on Nov 29, 2009
  • 173 Answers
SOURCE: i need the radio wiring diagram for a 1992 cadillac eldorado
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
Posted on Mar 25, 2010
Po141 heater circuit , bank 1 sensor 2
to check this the 02 sensor closest to the engine has a 4 wire connector, key off engine off. disconnect the sensor and on the sensor side connector thre are 2 white wires and 2 black or black and a blue. the blue is the heater usually. if its 2 black than you just need to check it with an OHM. meter. from 1 black -each white. and same with the other black.-both white if you dont get any reading than u need a new 02 sensor. if it reads check all engine fuse panel fuses with the key in engine run and engine not running. Fuses are all the little ones, some time they are labled 02 heater. please use a test light, do not pull these fuses! you will set every code and defeat the test process. good luck from Joe.
Dec 20, 2011 | 1996 Honda Accord
I have a 1992 jeep yj 2.5L I bought. The oxygen sensor wires were cut right off when I bought it. I had to replace the oxygen sensor. the wires on the new sensor are black, grey, and two whites. The wires...
When you bought the replacement sensor it should have included instructions on what color wires match. If possible I would return to the store you bought it from and ask for the included directions.
The blacks go together and the greys go together, but I am not sure which other ones go together without knowing the brand and P/N of the replacement sensor.
Jul 04, 2011 | Jeep Wrangler Cars & Trucks
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
I DONT REMMEMBER HOW TO SET UP MY GARAGE DOOR OPENERS SENSORS ?
You have to match the codes of the garage door you're trying to open.
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replace oxygen sensor for 4cyl 01" Accord - wires don't match
Don't put a universal oxygen sensor in your vehicle. You will have nothing but problems, and you will have to put an OEM one in it anyway.
May 30, 2009 | 1996 Jeep Grand Cherokee
Replacing Oxygen sensor on 2004 Hyundai Elantra VE 2.0L
yes it will work it is a uiversal 02 sensor place the black and gray wires together and connect to one black wire connect the white to white and the yellow to white this has a heated 02 sensor so twist them together to make sure it's right before you crip them together. the 02 sensor has a signal wire that is black and a heated wire that is black the two white wires are ground hope this helps and if you need more help post back here. the car only needs the heated part to warm it up faster to go into closed loop and the other white and black wire is the signal from the sensor telling the computer how much voltage you are getting from the 02 sensor.
Apr 19, 2009 | Lisle Pneumatic Oxygen Sensor Remover...
How do i wire a 2 wire o2sensor when the old sensor has 4 wire.
bank two section one would be more towards the middle of the exhaust, more on the higher part. If you have instructions then it should tell you which one is the power wire and which is the ground. If you don't have instructions you can use a multi-meter to test for continuity between wires. Peal off the ends of the wires to expose wire and set your multi meter to volts DC current (it wil say DC on the multimeter. Once you do the put the positive side (red) on one of the blue wires and the negative side (black) on the black wires. Mix and match until you have continuity in the corresponding two. Once you have done that you have found which wires go to what. the blue matching with white and the black matching black. Hope this helps you out and if you need more assistance let me know.
Mar 27, 2009 | 1995 Toyota Camry
Oxygen sensor wiring diagram
My 97 cherokee catalytic converter was stolen, oxygen sensor wires cut. the replacement is black, grey and white. the jeepicon1.png is different color. i need help knowing which wires get connected to which.
Jun 24, 2008 | 1997 Jeep Grand Cherokee
Oxygen sensor on a 93 civic dx
Jun 16, 2008 | 1993 Honda Civic 4 Door
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
