Question about Coffee Makers & Espresso Machines
Coffee spraying - Coffee Makers & Espresso Machines
Why is there water spraying from coffee head and surrounding area
Grind is too fine and the portafilter chokes when water hits the coffee; or the seal in the brewing head is shot.
Jul 31, 2014 | Gaggia Baby Coffee Makers & Espresso...
Bunn cwtf20-3 makes weak coffee
When you pull the basket out after its finished brewing what does the surface of the coffee look like? Are there 6 or so clearly defined dimples in the surface where the water pours from the spray head? Is the powder uniformly wet? If the answer is no to either of these, remove and clean the spray head. Use a descaling tablet or powder to soak the spray head and then use a small tool to clear the holes. Be careful not to make the holes bigger though.
Aug 08, 2013 | Bunn CWTF20-3 Automatic Coffee Brewer -...
Weak Coffee
First think to check is the spray head which pours the water onto the powder. remove the spray head, clean it and soak it in descaler.
reassemble and do a brew. When finished check the surface of the coffee has 6 dimples where the water has poured onto it and that the coffee is uniformly wet. If no dimples or dry spots, get replacement spray heads.
Jul 27, 2013 | Bunn VPS Coffee Maker
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
Can't remove spray head
There is a little tab on the side of the spray head that catches on a tab of the coffee maker, it is easier to empty the tank and turn the coffee maker upside down so you can see the liitle tab and place a small screwdriver or knive blade against the tab while turning the sprayhead until it is over the tab and off it comes.
Nov 09, 2011 | Bunn NHB Coffee Maker
My new Classic made perfect coffee for the first three weeks but now it sprays hot coffee in all directions from the delivery spout
Do you mean the spout OR do you mean the filter holder.If it sprays out too quickly from the outlet,it could be because the coffee is too dry, too coarsely ground or not compressed firmly enough in the filter. If it is spraying from around the filter holder it is probably old coffee grounds stuck on the rubber seal in the filter holder head (the part of the machine that the filter holder attaches to ) You can buy a special right angled brush for cleaning the rubber seal in place OR you can fold a washup sponge and use the corner to clean around the seal.
Jan 23, 2011 | Gaggia Classic Espresso Machine
Keurig leaks when I use filter and sprays around cup
One cause would be the filter is filled to tightly with your coffee. Try using a looser load. Your upper spay needle head may also have debris in it. Lift your handle all the way up and look up under the to see the spray needle. Using a paper clip, clean each of the three openings out in the spray head.
Nov 26, 2010 | Keurig B70 Coffee Maker
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
Flavia Coffee Maker coffee sprays outside cup
I bet that's wild thing to see. Ok, Is ther a basket that'ds supposed to be there? If not,heat up a large paper clip,straightened of course and run it yhrough the hole. If the nozzle will come off, clean the burrs of the edges of the hole on the inside. It sounds like it's restricted if it's spraying. Good luck
Jul 10, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
