Question about Cell Phones
My lumia 920 is totally blocked with the touch screen. Already put the sim-card out and pressed the -volume, power on/off button and the camera button the same time still the touch screen is blocked?
rafamp
  • 35 Answers
SOURCE: touch screen inoperative, buttons work
Hello
I have the same problems on my iTouch as well, here is what i do:
  • Restart the app
  • Reinstall it
  • Search for a newer version
Make sure u have the latest ipod touch firmware ;)
Posted on Feb 12, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
cvyoung
SOURCE: Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Posted on Feb 02, 2010
Kuruvi_Rotti
  • 961 Answers
SOURCE: When I insert another mobile
It may because of the Network Lock.,You need to Unlock the Mobile Phone from the Network Lock,You Can get the Unlock code at reliable cost at here
http://www.mobileunlocksolutions.com/samsung-s3650-corby/rs1wp9/ and Unlock the Phone....
Posted on Jan 17, 2011
  • 3 Answers
SOURCE: Samsung Star GT-S5230 Unlocked Phone with Full
The sim card is inserted above the battery which is located on the back of the phone. The attached photo shows what you will see under the battery cover. First, turn the phone off. To remove the battery, start by removing the battery cover which is the back cover of the phone. Press on the back cover in the center next to the camera and pull the cover down towards the bottom of the phone. The cover should slide off. Slide the sim card, face down with the "notch" on the top right side of the sim up underneath the small metal receptacle designed for the sim card. If you do not see the receptacle, look for an etching of the sim card on the phone that is above and to the right of the sim card receptacle. wickerjk.jpg
Posted on Mar 02, 2011
I have Nokia lumia 920 phone and can not turn on. What can I do?
Soft reset your phone.
Press and hold the Power and Volume Down keys simultaneously for 15 seconds. After some time, the phone may vibrate then release the button and the phone will restart.
Sep 09, 2017 | Nokia Computers & Internet
Lumia has been locked. How can I unlock it?
When the Phone is off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Release the VOLUME DOWN button when you see an icon (!) on the screen. Then press the following hardware buttons in this sequence: VOLUME UP->VOLUME DOWN->POWER->VOLUME DOWN - the Phone will perform a hard reset.
You will need to set up all your accounts again, as it will put your phone as default settings.
You did not mention the model of your Lumia but this should work none the less.
Mar 27, 2016 | Nokia Cell Phones
My phone will not turn on, it will not soft reset, and even having it plugged into a charger for 8 hours the screen just remains black. Any suggestions?
Try pressing and holding ALL buttons on your phone(volumes, home button, power, etc.) simaleataneosly for at least 10 seconds. It is also possible that the power cable plugged in is not working.
Dec 29, 2015 | Nokia Lumia 920 - High Gloss Red Cell...
Digitizer Problem
The digitizer could be bad or it's the wrong model type.
Dec 02, 2014 | Nokia Lumia 920
How Can I reset my Carl Zeiss windows phone
ok, you have to Factory Reset it.
It is going to delete all Data on the phone, but there is no way to avoid this.
Turn off the phone
Press and Hold together "VOLUME DOWN + CAMERA BUTTON + MENU BUTTON + POWER BUTTON"
do not release the button until the PHONE VIBRATES and the screen will appear again.
Than it will reset, removing the unlock code.
It can be tricky to do, so give it a few tries.
Sep 30, 2014 | Nokia Lumia 920 Factory Unlocked, Windows...
My Nokia lumia 920 has frozen, I took the sim card out and out it back in and said nice words to it but no go, can you help?
Is the battery fully charged?
If not charge it.
OR do a hard reset. You will loose your data though.
Turn off Phone
Press Volume Down, hold button while fitting the charger back and until you see an exclamation mark appear.
Press (in order); Volume UP, Volume down, Power, Volume Down
Phone should now reboot.
The whole reboot process may take sometime.
Sep 11, 2014 | Nokia Lumia 920 Windows Phone 8 Unlocked...
Need 2 unlock nkia lumia 920
Hi.
I see the website which offer to unlock Lumia 920 , I tried this website, they really unlocked my Nokia Lumia 920 from at&t, i would like Thanks & appreciate to Team of AT&T Unlock Code shop.They provide really good service , I hope this service provider will unlock your Nokia Lumia 920.
Once again thanks http://www.attphoneunlockingshop.us/
the link of http://www.attphoneunlockingshop.us/products/USA-AT%26T-Nokia-Lumia-920-IMEI-Unlock-Code.html.Thanks USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA
Nice vid. This site explains all this in very easy to order format:
Aug 12, 2014 | Cell Phones
How do I turn on a nokia lumia on its the carl zeiss one
"Google is your friend" goes without saying... but here goes:
Simply searching for "Nokia Lumia 920 manual" will get you to a PDF version of the User Manual:
http://nds1.nokia.com/phones/files/pdf_guides/devices/Lumia920/Nokia_Lumia_920_UG_en.pdf
Where you could've looked at page 10 to see that the Power/Lock key is located in between the Volume Up/Down rocker and the Camera button.
"Press and hold the power key until the phone vibrates."
Aug 01, 2014 | Nokia Lumia 920 Factory Unlocked, 32GB,...
My nokia lumia 521 screen went completely black after my phone asked to update. How can I fix this
I had this happen on my Lumia 920 a lot. I pressed and held the power button till it finally rebooted. I seemed like it took a minute before it finally rebooted, so don't give up after 10-30 seconds. If that doesn't work try the power button and volume down button till it reboots. Some sites say this is a hard reset that wipes the phone, but as a last resort, I tried it when the power button alone wouldn't "wake it up". When it rebooted everything was normal, so either it isn't a "hard reset" or it doesn't do the "hard reset" when the phone is locked up and the screen is black. I never tried the power and volume down reset when the phone was operational, so I don't know.
Aug 25, 2013 | Nokia Lumia 520 Unlocked Black
Need to remove sim card
Nokia Lumia 920 has a SIM tray on the top of it. You need a needle or a clip to open it.
If you need to put in a different SIM card in the device you should first make sure it is unlocked to the network provider. SIM unlocking will enable you to use your device with other SIM cards from other carriers. To Unlock Nokia Lumia 920 you need an unlock code. Follow the Link to know more about Nokia Unlocking.
Apr 22, 2013 | Nokia Lumia 920
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
