Question about Toto Home
Toto Neorest 600. The lid starts to open a few inches then slams down. I have reset remote and this did not fix problem.
dididsaythat
  • 291 Answers
SOURCE: washer won't start after lid is shut, if i slam it, it works!
sounds like your lid switch is loose ..look at the tab that sticks out of the lid and watch where it close's. inspect the switch see if it is loose or broke
Posted on Nov 29, 2007
SOURCE: Have to slam the lid
The same thing happened here. It turned out to be the lid switch. It can be accessed by taking off the back plate (behind the controls) by unscrewing three screws and two screw bolts -simple.
I removed the lid switch and tested it with an ohm meter - instructions are on this site. You should have continuity across machine-motor, as well as across machine -line. (These are labeled on the switch).
If you don't have a meter and you still want to see if that's the problem, after you have removed the lid switch, short the machine and line connectors, (you'll see these labeled on the lid switch so you'll be able to figure out which wires go with what) as well as shorting the machine and motor connectors. Both of these need to be shorted. That bypasses the switch and will activate the motor and controls.
That's what I did to confirm that it was all a "lid switch " problem. I ordered a lid switch from this site for $24.95 for the repair, and will use the "shorting process" to do a couple of loads of wash as I wait three days to get the switch. Good luck.
Posted on Dec 29, 2007
SOURCE: Have to slam lid down to get washer to start
Did not want to disect the entire machine to get at the lid switch. Couldn't figure out how to get the corner covers off so I figured we would continue to slam the lid until that no longer worked and then "call the guy". Thanks.
Posted on Jul 28, 2008
  • 23 Answers
SOURCE: my washer wnot agitate unless i slam lid
is the lid up during the filling process? the new washers will not agitate unless the lid is down. no need to slam the lid.. There is no pin to push the activator switch.. they are controlled with a magnet...
Posted on Jul 31, 2009
  • 3197 Answers
SOURCE: garage door opens a few inches and stops
On the rear of the motor unit near where all those white wires go you will find the 'up force'. Increase this 1/4 turn and try.
Posted on Dec 07, 2009
Remote functions erratic/neorest 600 why
It may be simply worn out.
Mar 17, 2018 | Lid Home
My neorest toto 600 shoots water everywhere when flushed
Reckon the toilet gets PO'ed f for being used and abused!
May 03, 2017 | Toto Home
Loose seat,piece missing or broken
Hello, I experienced similar symptoms with my Neorest 600. Do not call a plumber, they cannot fix!
I recommend calling Toto! Their support people will take the time to help you [this is what the experienced Toto plumber did that I hired :' ]
I had a leak too and ended up sending the whole electronics & seat in for repair. These one piece units do not require a plumber. Lo [Toto technical support] gave directions that I, a 60 year old woman who normally does not disassemble such an item was able to perform!
I realize some may not like my post to turn it to the manufacturer, but in this case it was the best solution for my fix.
Call first, get a case number and support person. Then they work quickly via email with you. This was my only toliet :' So i was with out a toilet during this period. Toto worked quickly to get my toilet back to me! The shipping time is what took the longest. Take a photo of the problem and you will be able to submit for your case via online.
Hope this helps! And hope your fix they will be able to send parts for so you are able to fix!
My excellent contact.
Lo Lam
Senior Technical Support
Technical Support
(888) 295-8134 ext. 1641Office
(888) 295-8134 ext. 4Tech Support
(678) 466-1287Fax
TOTO USA,Inc.
5351 Jurupa StreetOntario CA, 91761
http://www.totousa.com
May 29, 2014 | Toto MS990CGR11 Neorest 600 One-Piece...
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Sometimes the lid slams down. can the unit remote control be reset?
Yes. Remove the batteries and wait 1 or 2 min reinstall the batteries it should be reset.
If the same thing happens again you have a mechanical problem in the lifting and lowering mechanism.
Jan 26, 2011 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
I need to know where to put the electrical oulet for the toto toliet 600
Put it within reach of the unit and make double sure it is GFCI protected!!!!!!
Nov 08, 2010 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Home Logo
110 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
