Question about Singer Sewing Machines
Singer 99 not feeding heavy thread.
Singer 99 heavy thread not picking up. When using normal polyester thread the machine works perfectly. But I got it to sew leather, and when I put stronger slightly thicker thread in the machine will only reliability sew at full speed, which is no use as I need to be precise and sew round corners etc. If I try and sew slowly the mechanism around the bobbin isn't catching the thread on the needle. I've tried with and without material and the feed is..... Unreliable. Change back to polyester thread, perfect again. I've tried both heavy polyester thread and my usual hypron 17lb fishing line that I sew with on my old hand cranked Chinese machine. Any help would be much appreciated Thanks
  • Singer Master
  • 11,522 Answers
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Posted on Apr 19, 2017
  • 3 more comments
  • Nunya Business
    Nunya Business Apr 19, 2017
    Thanks for the reply. While not designed for leather, it is quite capable of going through 5-6mm of leather. The machine will feed and sew it no problem, but only at high speed, at slow speeds it's missing the heavier thread. With normal thread everything is prefect, but the thread isn't really strong enough for my purpose......
  • Nunya Business
    Catch 22........
  • R.A. Ellis
    R.A. Ellis Apr 19, 2017
    Yep, I use my old Singer to repair horse equipment. Even though it frequently has trouble piercing the fabric, I help it along with the handwheel, but I use 100% polyester thread so there are no problems picking up the bobbin thread.
  • Nunya Business
    Nunya Business Apr 20, 2017
    What weight thread do you use? If it's heavy enough for horse equipment should be ok for leather
  • R.A. Ellis
    R.A. Ellis Apr 21, 2017
    I just use polyester thread that I use for quilting. I think it's Isacord. Thin but tough stuff. Difficult to break with my hands.
I am trying to replace monofilm panels in a windsurfing sail, using a Singer 457 zig zag sewing machine. I cannot create a good zig zag seam when the monofilm is sandwiched between two canvas layers.
Joe, you might try a larger needle than you're using. You might also want to try a larger leather needle. You machine should take needles up to a size 18.
It sounds like the needle you're using is having a problem picking up the bobbin thread, and that might solve it.
Mar 09, 2017 | Singer Sewing Machines
I have a singer 201k sews fabric perfectly but I wanted to do some leather I bought a walking foot attachment leather needles and heavy duty thread but the machine is not stitching properly very tiny...
Sounds like it is still not feeding smoothly, Try putting some clear tape on the bottom of the foot and tissue paper under the leather. Leather is tricky sometimes.
May 31, 2014 | Singer Sewing Machines
Bobbin thread is not being picked up when I free motion quilt
Duh. It was the breaker. Always check the breaker ...especially around Xmas!
Dec 04, 2013 | Janome Memory Craft 9000 Computerized...
Polyester thread fuzzing on my 328k singer. using an 18 needle on marine vinyl
try changing the needle--just incase the needle tip is damaged
check for burrs in the thread guide area where the top thread runs
or even on the needle plate
Jun 05, 2012 | Singer Sewing Machines
I own a Singer 258, the needle does not pick up the bobbin thread
is the needle the right one for the machine?
is the needle & thread correct for the fabric?
it's possible that the machine is out of time & would have to be retimed by a sewing machine shop
Apr 02, 2012 | Singer Sewing Machines
My White 5500 sews perfectly on the top, but the bottom thread is tangled and messy. I have tried to adjust the tension according to the manual but nothing seems to work. Help!
This is a really common problem especially on side bobbin machines, and the manual will tell you it's a tension problem but it's often a more general thread feeding problem. First make sure you have a good quality thread that isn't old or sticking as it comes off the spool. And more important it can't be too heavy, especially in certain fabrics and with a fine needle. A too heavy thread will cause all the problems you describe.
If your machine uses a bobbin holder and it has a tensioner in it make sure it's clean and well adjusted and has no gummy residue on it. And finally look at the bobbins themselves, I understand older machines work better with metal bobbins vs plastic.
These are very generic solutions but I had similar befuddling problems with a newer Brother side bobbin machine and was tearing my hair out over the thread bunching and Brother support kept insisting it was a tension problem or improper thread routing.
Turned out I was using too heavy a thread.
Since then I picked up an older (1990?) Singer Meritt 4530 from Goodwill for $20, but it's a more expensive top bobbin machine and NEVER bunches or malfunctions. I'm sold on the top bobbin design now, the mechanism inside is more complex but the thread feed from the bobbin is more direct and simple leading to less sewing issues. So you pay more for less headaches.
Jun 01, 2011 | White Sewing Sewing Machines
I just had my Designer 1 serviced. Now it has problems with sewing polyester thread, which I used a lot before the servicing. It sews perfectly with rayon thread so I'm thinking the tension is too tight...
Your dealer should keep a record of what was done to your machine. Actually, they should give you a record of what was done to your machine.
Calmly let them know that it used to do this and now it won't. Maybe they can take care of the problem for you.
If they are not willing to help, take all of the repair documentation that you have on what was done and contact another Husqvarna Viking dealer to see if they can help.
Dec 13, 2010 | Husqvarna Designer I
The top thread is not picking up the bobbin thread. Singer Model 7422
Check your needle and make sure it is not bent, needles should be replaced after about 8 hours of sewing and that they are the right size for your project. Also use the same weight of thread, do not mix ie. cotton or polyester. Then check your threading, did some thread get tangled? Or sneak out of a guide? Hope this helps.
Oct 03, 2010 | Singer 7422
Singer 132q sewing machine
Try this. it's a online manual.
Aug 10, 2008 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
