Question about The Health & Beauty
Sometimes my shopright scooter fails to move forward or backwards when I turn the key on.. if I disengage the free wheeler lever then engage it again is back to normal. how can I fix this problem
  • 2050 Answers
SOURCE: gear select lever is very loose. It move forward
There is a pin that goes through the shifter that hold it in place, along with a spring just inside where the end of the shifting lever is, that makes the lever "return" after you pull it back to shift. These springs can break and bind up. Take a look at both.
Posted on Aug 14, 2009
SOURCE: Scooter won't move forward or backward
jdl0755, I'm having the same problem with my DKS-200. I was wondering if you determined the problem? I'll let you know if I figure it out with mine.
Posted on Dec 17, 2009
  • 317 Answers
SOURCE: 2004 suzuki XL 7 engage 4x4 and it will not
most 4x4s have to go in reverse to disengage from 4 wheel drive to 2 wheel drive.
Posted on Jan 03, 2010
  • 414 Answers
SOURCE: My daughter gave me her old Cub Cadet model 2145
linkage is connected correct? Did it work prior correct? Did you prurge after changing fluid
Posted on Mar 05, 2010
Testimonial: "Well you were exactly right. I had to remove the two plugs on top and kept operating the lever until I got the oil to run out the top. Runs great."
  • 313 Answers
SOURCE: My father inlaw has a
If you have followed all the trouble shooting guide in the back of the manual then it could be one of a few things. either the Wig-Wag control is at fault (the lever you press to go forward/ backward) or the control/drive unit is at fault. You will need to take it to a service centre to have it looked at or repaired. Shoprider are made by Roma medical and their web site is ;- if you need a manual you can download from here.
Posted on Aug 09, 2010
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Mar 01, 2016 | Health & Beauty
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Scooter won't move when forward/reverse engaged.
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
My scooter won't move! i turn the key, plenty of battery power, all lights, horn etc working but will not move forwards or backwards, when i pull the controls all i get is a beep. any thoughts?
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 28, 2012 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
Seems to die when fully charged. one push with foot and it lurches forward and runs a while then won't go again after stop until manual push and then lurches forward again. is something not connected...
hi ,
so first take off the seat, please be carefull how you do this as they can be heavy,
Now remove the cover , again carefull as there may be some wires connected for the lights so discconect these,
Now look for the break located on the side of the motor ( can be a gold colour), check the wires here, make sure they are a good connection, now check the battery teminals , are they loose check the wiring here, now does the brake click when you move the throttle lever, it may be a really faint click, no click then check the connections leading to the controller, normally a black or blue box.
IT could also be the fact that the batteries are faulty and appear fully charged, again check the charger making sure it is really charging , last of all it could be in fact a controller fault or brake fault
Please rate my help.
Nov 11, 2010 | Pride New Mobility Victory XL 4 Wheel...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
The Pride GoGo 4 wheel scooter does not move forward or backward. when the key is turned on the batery meter displays a full charge. When the forward or reverse lever is pressed the unit beaps numerous...
Hi. How many beeps between pauses? This is a fault code.
A couple of problems might cause this fault. Is your free-wheel lever in the correct place. These levers operate a switch, that tells the controller that the brake is disabled, this stops the controller from driving the scooter with out brakes.
Might also be caused by a stuck brush in the motor. This is usually caused by the caps that hold the brushes in, not being tight enough. Check the brushes, make sure they slide in and out smoothly, retighten the caps. Be carefull because these caps can crack easily.
Good luck. Neil.
Jun 11, 2010 | Health & Beauty
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Mar 07, 2010 | Health & Beauty
Health & Beauty Logo
26 people viewed this question
Top The Health & Beauty Experts
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
