Question about Dishwashers
Kdfe104dss2 dishwasher is not draining. Filter has been cleaned
3 Suggested Answers
ngafm
  • 166 Answers
SOURCE: Whirlpool quiet partnerII dishwasher
Peace Friend,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
That unit has a stainless steel soft food disposer built in to it!
That should not be the problem!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 05, 2008
  • 64 Answers
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
Posted on Aug 26, 2009
Oe code. Will not drain. Steps to fix?
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I am getting an OE code on my dishwasher
Hi
Daniel
Aug 24, 2011 | LG LDF6810ST Stainless Steel Built-in...
Does not drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 21, 2011 | Electrolux Frigidaire Professional Series...
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Daniel
Jun 19, 2011 | Maytag Dishwasher
Water will not drain completly.
Usually there must be a filter screen in the dishwasher which can cause this to happen. It goes to the drain . If there is accumulation of food particles in the dishwasher filter screen then draining may be obstructed which can cause the water to be stranded at the bottom.
Usually the filter is located at the back of the dishwasher near the drain. It is usually held in position by means of clips. You can just pop it out.Pour some hot water in the drain and clean the drain line also.
If after cleaning this filter also you are facing the problem of water not draining then the drain pump must have gone bad.
Feb 27, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Draining not
Feb 15, 2011 | Maytag 24 in. MDB9750AW Dishwasher
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher won't drain
To exactly tell you where the filter is locate and how to clean it please specify the brand and model number of your dishwasher.Usually the filter is located at the back of the dishwasher near the drain. It is usually held in position by means of clips. You can just pop it out.Pour some hot water in the drain and clean the drain line also.
Dec 22, 2010 | Whirlpool Dishwashers
My dishwasher cleans ,but does not drain the watr fully. Please help. Thanks
Hi
Oct 20, 2010 | Maytag Dishwashers
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
