Question about The Audio Players & Recorders
When the record plays it changes speed every few seconds from the speed it should be 33 to 45 etc...i changed the stylus thinking that may help but it did not;
  • 1 more comment
  • Rach lyons
    Rach lyons Apr 20, 2017
    it is It. Innovative technology wooden music centre with recordable cd player; model ITVS-750; the trouble shooting guide it came with or googled offers nothing about such a problem
  • solver2010 Apr 20, 2017
    I would suggest that you send an email to them. Here is some contact information:
    http://www.ithomeproducts.com/support
    If I cannot help, at least I will try to refer you to where you CAN get some help!
  • Rach lyons
    thanks!!
    Master:
  • The Master
  • 923 Answers
What kind of record player is it? Make, model, year of manufacture, etc.? There should be a sticker or plate somewhere that tells all that info.
Posted on Apr 19, 2017
How do you replace or change a stylus
to change the stylus you pull end of the cartridge towards you, they are push in, and slide out very easily. Not all stylus are removable but the good makes always are. To change the cartridge, there are two screws and four pull off gold plated connectors.
Feb 14, 2016 | Audiovox Jensen JTA450 Turntable
Playing records too slowly
It's likely that the belt has moved off where it should be. If the stylus was damage it would slide across the record or cause poor sound. It would not affect the speed unless there was too much pressure on the stylus, but you would feel that as the head of the arm would feel heavy.
May 24, 2013 | Crosley Conductor CR73 Turntable
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Scratchy noise on my record player
Sounds like its time to change the needle [Stylus ] , there are a few types But the two most common are Saphire and Diamond Stylus pay the extra and get a diamond if you can , Hope this helps
Jun 01, 2009 | Creek 5350SE Amplifier
Olympus stylus 790 will only record video for 10 seconds?
The duration of higher quality videos is reduced to 10secs. You can only record lower resolution video for a longer duration by changing the type from Super High Quality (SHQ) to either HQ or SQ. This can be done by turning the menu whell to the video option, pressing the menu button, choose Image quality and scroll to HQ and press menu again. You will now find you can record for longer.
Jan 01, 2009 | Olympus Stylus 790SW Digital Camera
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Playback speed problems...
The Play button controls speed of play back. If you hold the button two long it changes the speed. Press Play and then release and press again until the speed you are looking for is obtained. Be careful not to push the play button mulitple times once it is correct.
Apr 26, 2008 | Olympus DS-2 Digital Voice Recorder
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Axim Record Button Does Not Work
Try taking off the left black rubber stripping and see if the button underneath is lined up correctly. Perhaps take a look inside to see that all the contacts are good.
This site will help with how to take off rubber part and open the Axim: http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_axim_takeapart
Sep 14, 2005 | Dell Axim X5 Pocket PC
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
