Question about Cub Cadet Garden
Model ltx 1040 cub cadet went to engage blades pto lever locked half way in HElp Jim
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 4 Answers
SOURCE: electric pto does not engage cub cadet 1040
if its an "GENERIC" problem,someone must have the solution..i would start with the motor, apply voltage direct to motor, making sure it worked,then work back through all the wiring,fuses,relays,solenids,sw,etc..etc.
Posted on Dec 14, 2009
  • 3074 Answers
SOURCE: Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
Posted on May 04, 2011
BAMOUT
  • 2478 Answers
SOURCE: cub cadet 1040 blades spinning when pto isnt engaged
Sounds like you forget a spring or the routing belts are
wrong.
Posted on Sep 30, 2012
The lever to engage the blades on my Cub Cadet rider LTX 1042 KW has no resistance the the blades do not engage. Did a part possibly break off or come loose?
The blades are engaged electrically via the PTO on the engine shaft.
Check the connector and wiring to the PTO unit, or the electrical plug on the engage switch.
Oct 09, 2016 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Where do i attach the PTO deck engagement spring on the cutting deck of the 2009 cub cadet LTX 1040 PTO deck engagement cable attachment on the cutting deck
Wherever it was that you took it off from. If it broke, then look to see where a spring might be while you have a friend slowly engage and disengage the assembly. If it's an electric engagement situation, bring it to a shop. If you don't have a friend, sorry. I'll be your friend.
Sep 25, 2014 | Garden
Why will the blades not engage on my 2009cubcadet 1040
PTO switch maybe bad or fuses blown. Or possible a safety switch is bad. If none of those the PTO clutch is bad.
Sep 06, 2014 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Cub cadet 1040 blades spinning when pto isnt engaged
wrong.
Sep 29, 2012 | Cub Cadet Garden
May 04, 2011 | Garden
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
175 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
