Question about Bosch Saws
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
  • Bosch Master
  • 20,966 Answers
Video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Posted on Apr 19, 2017
Testimonial: "I found What I needed by following his directions to You Tube, and just by chance the procedure for changing the blade for the Bosch PST54 is the same for my 1581VS"
How to change blades on a bosch 1587avs
Turn the handle on the top counterclockwise like shown in the video.
But the handles break often, see the link for a parts breakdown
Bosch nbsp1587AVS nbspTop Handle Jig Saw
Feb 09, 2015 | Bosch 1587Avs Jig Saws
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
There are three dails on the 1581vs jig saw drill one is for the speed whats the other 2 for
The numbered wheel on the top handle is for speed control. The sliding (ratcheted) lever on the side near the blade is for controlling the forward motion - the blade can either go straight up and down or follow a slight orbit on the downward cutting cycle. The third dial is on the bottom and is used to adjust the angle of the blade w.r.t. the surface of the wood being cut.
Dec 26, 2011 | Saws
Model 1581VS Bosch jig saw, Cannot get blade changing screw out
from what I remember you should be able to just unscrew it and it comes out the top end of the spindle. when you get it loosened you might have to "TAP" on the side to get it out. There might be some debris or a burr on the threads making it difficult. Go to "ereplacementparts.com" and you can look at a breakdown for this tool and the screw is position #53. The part number is 2603400000.
Apr 23, 2011 | Bosch Saws
Change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Oct 06, 2009 | Bosch Saws
After changing the blade on a bosch 1587VS jig saw the blade turns sideways when sawing. How is this corrected? Thanks
I would recheck the installation of the blade and the tightness. If still a problem there is a spring under the lever that might have broke (they tend to do that) and is jamming the spindle. Let me know and I will help you with the breakdown for this tool
Jul 26, 2009 | Bosch Saws
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Apr 06, 2009 | Bosch Saws
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
BOSCH: 1581 VS... BROKEN BLASDE HOW TO REPLACE WITH NEW BLADE
hi there is a hole on the top of the handle at the front when holding it it is just in front of your hand you need a long series flat head screwdriver to loosen turn the blade sideways and out she comes
hope this helps glenn...........
Nov 09, 2008 | Saws
Saws Logo
129 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
