Question about Boating
It's a boat engine - Boating
Do you have to remove an eveinrude 40 hp from the boat to repair the tiller?
You should be able to get to everything on the tiller handle while the engine is installed.
BUT, on some boats it can be easyer to remove the engine to get access. This just depend of the engine bay.
Nov 08, 2017 | HP Boating
How much does this boat engine weigh?
'this boat'? There is no boat mentioned, so difficult to tell.
<year> make <horsepower> specifications
Mine would be
2014 Mercury 60 specifications
That would lead me here
and the answer
Dry weight *Lightest model available
  • 260 lbs / 118 kg
Mar 31, 2016 | Boating
Outboard will not start tried changing spark plugs,fuel filte,r clean fuel
Top 25 Reasons Your Boat's Engine Won't Start ' Boating ...
BoatingAug 10, 2012 - A list of things to check for outboards, inboards and sterndrives. ... Top 25 Reasons Your Boat's Engine Wont Start. Even the mood created by ...
Basic Trouble Shooting When Your Outboard Won't Start ...
? 2:18
Feb 23, 2014 - Uploaded by
... on basic troubleshooting when your boats outboard won't start will help you get ... Outboard won't crank or turn over, electricstart not working ..
Nov 23, 2015 | Boating
How do you remove a gas tank from a Bayliner indoor/outdoor boat
I did not know Byliner made indoor boats. If you are referring to an I/O engine boat, it is usually under the floor, along side the engine, etc. Screws and cutting sealant is usually involved. It can be a real bear. Ask a Pro.
Mar 19, 2015 | Boating
Where are the engine codes located on a 1970 Pacemaker 45' boat. Where are Boat Identification codes located on pre 1972 boats? Specifically this Pacemaker?
With a boat 44 years old, your boat engines may have been replaced or at minimum, overhauled. You might resubmit your question with some easy information you can add:
Gasoline or diesel engines?
Many were Crusader engines & you can usually see the name like this on the top portion of your engines.
You can see what color the valve covers are (blue, black, etc.).
You can see if they are V-8 engines if they have two long valve covers on top.
Most engines have a name plate on them (yours may be gone if original engines). Any mechanic you run into might find it quickly or recognize the engines.
Enjoy your boating. Pete
Apr 04, 2014 | Boating
I have a broken motor strut on my wellcraft boat
engine mount thats bolted to side of engine ?? if so then lift engine enough to remove and repair or replace it !
Jan 24, 2014 | Boating
When was the first hybrid engine for sports boats created?
The first hybrid engine for sports boats was created back in February 2009. For more information, check out this website:
Feb 06, 2013 | Boating
What are the types of engines for boats?
The main types of engines when it comes to boats are: steam engine, gas turbine, diesel engine, steam turbine, and gasoline engine.
Jan 10, 2013 | Boating
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp merc is on a 13ft saracen,and with two of us it takes a while to get i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
What engine should fit my 28´bayliner boat
Yes there is. Saw one at a boat show and I believe it was also Swedish. You may want to look for used replacements on the web. I do not know where you live, but there are boats on the Great lakes with low hours because of the short boating season. There are also victims of hurricanes with good engines down South.
Jun 18, 2009 | Boating
Boating Logo
29 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
