Question about Kubota Garden
I have a Kubota L5740 and shredding a field most of the day. All of the sudden the tractor stopped running and will not start. It will turn over and crank but will not start. Any ideas?
It has fuel, coolant and oil, the rpms just dropped off and it did not sputter to a stop, it just turned off. fuses are fine at least the ones I know of.
SOURCE: "99 cherokee classic: sputtering when cold
I actually had the 02 sensors changed (even though my check engine light never came on) and the IAC (Idle control Valve) and it seems to be running fine.
Posted on Sep 19, 2008
  • 135 Answers
SOURCE: 1997 Pont sunfire turns over wont start
replace engine control module
Posted on May 13, 2009
  • 40 Answers
SOURCE: 2003 Kia Rio Cold Start Problem
Good source for Kia its free to register NO STRINGS
Posted on Jun 01, 2009
  • 14 Answers
SOURCE: Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Posted on Oct 10, 2009
  • 146 Answers
SOURCE: Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Posted on Jul 03, 2010
I have a Kubota G6200 hst lawn tractor. Mowing the other day and it started sputtering. Then the forward/reverse pedal quit working.It starts great. just will not move.
Obviously you have an issue with the drive to the rear wheels.. Need to check the transmission of power from the motor and see where it stops. Could the the tranny or shifting mechanism at fault
If there is a belt drive check for a good belt or one that has not stretched and slipped off its pulley.
Aug 22, 2016 | Kubota Garden
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
My Kubota BX2200 will not run it will run fine if you hold the key to start but when you let it go to on it stops running
Sounds like the fuel shutoff solenoid. cost around $!50 for the part.
Whats happening is when you turn it over the solenoid is holding the pin and when you let go of the key the solenoid is releasing the pin and shutting off the fuel.
Hope this helps
Apr 17, 2015 | Kubota Garden
Go to Kubota Kpad Site. You must be running Windows Internet Explorer or the correct add-ons to access to site. Also you need to know which size deck you have.
Here the front part link.
Kubota Tractor Corporation Parts
Apr 05, 2015 | Kubota Garden
Kubota zero turn mower
You probably picked up some contaminate from the bottom of your tank... Try some carb spray but it will probably require a good carb cleaning...
Aug 02, 2014 | Kubota Garden
Kubota tractor got of seat and now won't start
Most seats contain a safety switch.
go online (like I just did) and type in "Kubota tractor seat safety switch" then scroll through the pics to see where the safety switch is. This switch is to prevent one from getting off the tractor while it is operating. DO NOT REMOVE IT. It will only put you and someone who doesn't know it is gone to have an accident maybe a serious one.
Feb 20, 2014 | Motorcycles
Kubota will not start again
The pushrod may not been in lifter.
Sep 17, 2012 | Kubota Garden
Garden Logo
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
