Question about Saws
Replacement parts for kobalt 71/4 slinding compound miter saw with laser guide
  • 199 Answers
SOURCE: replacement part not available
I had the same problem and the parts are available but they are expensive. There isa spring loaded double contact switch. Take it apart. You will have to drill the rivets out and reassemble with some sheet metal screws or machine screws and nuts. Careful when you open because the parts may fall out. You will want to know how it is built. Usually only one contact goes bad so hard wire the side without continuity(solder together & heat shrink or black tape). The rest is just good mechanical inclination. You will figure it out.
Posted on Jul 05, 2009
  • 7 Answers
SOURCE: change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Posted on Oct 05, 2009
rowdy45176
  • 2176 Answers
SOURCE: Need a user's manual for Craftsman compound miter
go to Managemyhome.com and type in your model number and on the second option for the manual click on it. the manual is 38 pages long, let me know if you need more help
Posted on Jan 02, 2010
Testimonial: "Found the manual with instructions for changing blade, etc. Just what I was looking for. Thanks, rwhermes"
  • 4088 Answers
SOURCE: I need a left-hand metric thread bolt that holds
Go to: searspartsdirect.com and enter the full model number minus the decimal point. Full drawings of all replaceable parts will be displayed as well as parts lists and prices. Hope this helps!
Posted on Mar 30, 2010
  • 2527 Answers
SOURCE: I have a Ryobi 10" sliding compound miter saw with
No i have a hatachi 10 inch miter saw with laser it dosn't work the laser if your in the light. If the sun is out you can't see the line so use it in the shade and see if it works and i use mine a lot its a grate tool if not you may have a problem with the conection but then i have been moveing away from ryobi tools they used to be realy good but home depot has kind of draged them down. Now they make the tools for home depot to there speic's
Posted on Dec 20, 2010
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
I need manual for Kobalt sliding miter saw 71/4"
try going to the store where you got it. sounds like a LOWES product
Jul 03, 2014 | Bosch 12" Compound Miter Saw 3912
How do you adjust the laser from side to side on a Kobalt 10-in 15 Amp Slide Compound Laser Miter Saw
goto https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Laser-Compound-Miter-Saw/3512785 and scroll down to guides and documents download PDF
Dec 22, 2017 | Measuring Tools & Sensors
User manual for 251946 kobalt sliding compound miter saw
Try to find it on amazon, Amazon com kobalt saw manual, they have great amount of books, so, maybe you are lucky. I hope this helped. Cheers
Dec 02, 2012 | Bosch 12" Compound Miter Saw 3912
I need manual for kobalt sliding miter saw sm2505lw
Call-18883Kobalt and they should be able to help you. Listen for the prompts to make sure you get the right service agency for miter.
Sep 15, 2010 | Bosch 12" Compound Miter Saw 3912
Laser guide on Bosch 4410L miter saw is off.Can it be adjusted?
I looked thru their onwers manual and the parts breakdown and find no reference to adjusting the laser. I would recommend calling them direct at 1-877-267-2499 for assistance. I wish I have better information but this is all I can find. Good Luck
Nov 15, 2009 | Makita 10" Dual Slide Compound Miter Saw...
10 Craftsman Compound miter saw
toolpartsdirect for parts diagram or dewaltsrevicenet.com
Dec 15, 2007 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
1,014 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
