Question about Garden
How often should belt be changed?? I got vibration,it's not blades.
  • 65 Answers
This depends on how much grass you cut & how often you cut it. I would change my belts every 2 -3 years with normal cutting unless your running over branches & leaves I would replace every year. Take a look at your belt if you notice any cracks, frays or cuts I would replace as soon as possible. Hope this helps.
Posted on Jul 24, 2009
After starting my lawn mower, it runs for a short time, vibrating and then stalls (stops).
Hi Abraham:
The vibrating could be coming from the blade.
Check:
- the centre bolt to make sure that it is securely attached,
- that the underside of the mower deck is not obstructed with grass
- that the blade is not bent.
If it will not start at all now you may have a sheared key on the flywheel.
May 13, 2015 | Garden
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husquvarna deck vibration
It is absulutley possible, cheap belts have a different diameter through out there length and will set up a vibration, also slack belts will set up vibrations, you also need to the check the balance of the blades, and the condition of the blade pulleys
Jun 26, 2012 | Husqvarna Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck vibrates excessively - Replaced blades and tension arm. it Still vibrates.
Make sure your blades are engaging the spindle correctly and are centered. My deck did this after I mounted new blades and had 1 of them slightly off center. Also, you may have a bad deck spindle bearing. Hope this helps you.
Sep 15, 2009 | Garden
I have a crftmans rider ltx 1000 , i was cutting the lawn picked up a cable which wraped itself arouf the mandrels for the blades and stopped the mower , got cable removed started right up no problem ,...
Yes, if you jammed something in the blades and the belt stopped, the engine pulley wore a thin spot in the belt.Every time that thin spot runs around a pulley it rides deeper in the pulley making it vibrate.Take the belt off and you should be able to see or feel the spot where the engine pulley burnt it. Replace the belt and it should fix it.
Jul 31, 2009 | Craftsman Garden
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
