Question about The Computers & Internet
What size physically is the screen - The Computers & Internet
Adjust picture to fit screen
Change the screen resolution in your Operating System desktop.
In Windows, click on Start/Help/ enter "screen resolution" in search field.
May 02, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
Tip
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Tip
Increase Physical memory of the system. Increasing Physical memory will increase...
Increasing Physical memory will increase the performance of the system.
1. Right click My Computer - Select Properties.
2. In property window Click on Advance tab --- Performance -- Settings.
3. In Performance Options window -----> Virtual Memory option Click Change button.
4. In Virtual memory window --- Select C drive --- Click on custom Size.
5. Change initial size to 2000MB & Maximum size to 4000MB -- Click on Set button.
6. Click OK and close all window. Restart system.
Regards
Achalesh Prem P
Vote for me
on Mar 05, 2010 | Computers & Internet
How do I fix the resolution it is was to big
if you are in Xp right click on the desk top. go to Proporties, goto Settings, use the slide to adjust the screen size of the pixel resolution you want. click apply.
the smaller the number the bigger the font. so an 800 x 600 is huge where as a 1920 x 1080 is small. (you can have different resolutions it doesnt matter your screen size physically)
Dec 22, 2011 | HP Compaq FS7600 17" CRT Monitor
What size battery for a 1996 Jeep grand Cherockke for cold weather
you have to go with the same physical size that you have so it will fit. BUT, get the highest cold cranking amps you can for that physical size. more cold cranking amps in cold weather reall helps at times
Jan 30, 2011 | 1994 Jeep Grand Cherokee
Can only get "4:3" and "compressed 16:9" screen format. Want full "16:9" not compressed. How?
HDTV ready means that it will process HDTV signal to be viewed on you set. The size of your screen is still in a 4:3 ratio. Unless you have a true 16:9 size sceen you cannot get the full 16:9 picture. The actual physical size of the sceen is what makes TV's true HD or not. In other words, the screen has to be twice as wide as it is tall or 16:9. Your screen is almost square or 4:3. It can only show a compressed version of the 16:9. Thanks for using fixya.
Dec 13, 2009 | Philips 60PP9202 60" Rear Projection...
How do I expand my Tv screen
If the physical size of your screen is 4:3 the only thing it can show is a compressed version. The screen is physically not able to show the true 16:9 version. The true 16:9 HD signal has been developed to show on a screen that is twice as wide as it is long or 16:9 ratio. Your screen is almost square or 4:3 ratio. I hope this helps. Thanks for using fixya.
Dec 13, 2009 | Philips Televison & Video
Display size / resolution
Hi thanks for this but no to no avail. There is nothing wrong with the display itself - everything works but the problem is that the VIRTUAL size of the screen is 1500 x 950 instead of 1440 x 900 if you get my meaning. I wish i could find a way to shrink back the virtual screen size to 1440 x 900 so that it fits the exact physical screen. ie. if i was to play a DVD on full screen i would only see 95% of the picture because the virtual screen is larger than the display. And the virtual screen would move right if I shifted my mouse to the right edge. Still puzzled.
Sep 19, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Picture Size
check your picture setting if it is on zoom, you can set it back to auto cinemal or panorama
Sep 09, 2008 | Polaroid 3211TLXB 32 in. LCD Television
JVC AV2649S Picture Too Large
you can see the diagnostic menu in jvc as you press both at the same the display and the picture mode buttons
Oct 17, 2007 | JVC AV27F476 27" TV
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
