Question about The Computers & Internet
What size is the screen - The Computers & Internet
  • yadayada
    yadayada Apr 19, 2017
    On what?
How do i get my screen to normal size
Right click your mouse on the desktop and go to Screen Resolution and make sure your laptop screen is set to the default size. Otherwise, you may have tapped F11 which enlarges your screen to the expanded size.Try tapping F11 again.Also you can go to VIEW on your menu bar and then ZOOM and then click Reset.
Aug 25, 2014 | Sony VAIO Computers & Internet
Monitor size not matching laptop screen size
you will find more options about screen control......that is about size........in properties......okay?? best of luck.........
Mar 21, 2014 | Computers & Internet
I cannot increase the size of my computer screen.
Describe your problem with details, screen size or display size,
if the problem with display then reset your display resolution from display property, according to your display screen size. If the Problem related with screen size then in laptop not possible to increase. if youe need more help then hit me at jogindersingh47atyahoo.com
Aug 17, 2013 | Computers & Internet
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
My screen size is to big need to make it some smaller
your screen resolution is set to 800x600 or less so right click on screen
in the context menu select properties and now click on settings tab
here in less and more option you will see the slider that you may set
to the required screen size ,standard screen size is 1024x768
once selected press apply and ok.
you are now done with it and you will see that screen size is at optimum
level
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
Full screen
Press the F11 button to get full screen.
To return back to normal screen, press the F11 button again.
You can also hold down the CTRL key on the keyboard and Scroll down the scrolling button on the mouse.
To revert to normal , again hold the CTRL button on the keyboard and scroll upwards.
Cheer
Uttam
Jul 12, 2010 | Advent Netbook
Full tv screen is not being diplayed horzontally.
First thing to check is the picture size. You can view many program formats in a variety of picture sizes
  1. Natural
  2. TheaterWide 1
  3. TheaterWide 2
  4. TheaterWide 3
  5. Full
  6. 4:3 HD
  7. Native
  8. Dot by Dot.
The format of the image will vary depending on the format of the signal you are currently watching from you cable or satellite provider. Select the picture size that displays the current program the way that looks best to you.
To select the picture size using the remote control:
  1. Press I on the remote control.
  2. While the Picture Size screen is open, you can do one of the following to select your desired picture size:
• Repeatedly press I.
• Press the corresponding Number button (0–6) while the Picture Size screen is open.
• Press B or b while the Picture Size screen is open.
To select the picture size using the menus:
  1. Select Picture Size in the Theater Settings menu.
  2. Press C or c to select the desired picture size setting.
  3. Highlight Done and press T.
Some of the picture sizes may not be available depending on the receiving signal format from your cable or satellite provider (those will be “grayed out” in the Picture Size screen).
Second thing to check is the Native Mode which restores the size of the picture by the 3-5% that is generally lost during the normal over scanning that occurs on traditional sets. It also avoids unnecessary scaling of 1920 x 1080 HD signals. I hope this helps and good luck!
Feb 24, 2010 | Toshiba REGZA 52RV530U LCD TV
I cant adjust my picture size to normal on my Sony Wega 51" TV
the screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Apr 21, 2009 | Sony KP-51WS520 51" Rear Projection...
Must have pressed the zoom by mistake and my mail screen is far too large. How do I get the screen back to "normal" using the mouse. Thanks
HI HAVE YOU CHANGE JUST THE PAGE SIZE ALL THE SCREEN SIZE
PAGE SIZE IS EXPLORER VIEW THEN TEXT SIZE.
SCREEN IS RIGHT CLICK DESK TOP THEN PROP THEN SETTING THEN CHAGE SCREEN RESS
Dec 03, 2008 | Computers & Internet
Computers & Internet Logo
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
