My washer dryer door won't open - is it broken?
    Top Expert:
  • Washing Mach... Master
  • 79,865 Answers
Try unplugging the machine for 5 min's to reset the system, if that fails you need a service technician to fix this.
Posted on Apr 19, 2017
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Dryer won't come on
If the timer is still making noise like it wants to run then you may have a blown thermal fuse on the blower housing, can be tested for continuity, if the timer is not making any noise then check your door switch, if the door switch is broken dryer thinks door is open and won;t run,
Jan 24, 2014 | Whirlpool Dryers
Samsung washer door wint open
Try disconnect from the power source for some minutes and try again probably the machine is having some error.
Jun 12, 2013 | Washing Machines
Electric dryer will not start
If the filter chute or vent to outside is clogged the skinny white fuse mounted on the blower next the the control t-stat melts. This kills power to the door switch circuit. The door switch circuit stops the motor whenever the door is opened using a door switch. If the door switch lever is broken or the door switch is broken she won't rune either. Now here is my home movie and whirlpool dryer page:
DAN'S DRYER REPAIR PAGE
Apr 28, 2013 | Whirlpool Dryers
Hotpoint dryer won't stay on
The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
Apr 27, 2013 | Dryers
May tag washer Neptune door won't open
what is your model number is then we can get started then
Oct 25, 2012 | Maytag Clothes Washer Dispenser Bezel...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
Dryer electric when i push the start button nothing happpens
Make sure you have 220 Volts of power at outlet, check circuit breakers. Then, with dryer door open, look for door switch actuator on door. It may be broken. Use flat screwdriver to manually push door switch in, then push start.
Feb 21, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
