Recall numbers for WF306LAW/XAA WASHERS - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 77,947 Answers
Sorry we do not have this information at this website.
Posted on Apr 19, 2017
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
May 10, 2017 | Samsung Washing Machines
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ... > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
My WF306LAW-XAA Samsung washer will not stop filling with water and hence will not advance to wash cycle. Do you think it needs a new mixer valve?
No, you have a water level switch problem. Simple solution is to pull the hose from the water level switch and blow into the hose to clear out the debris. DO NOT BLOW INTO THE WATER LEVEL SWITCH!!! It will break!!! Replace the hose back onto the water level switch and it should work fine. Good luck
Jun 17, 2011 | Samsung Washing Machines
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Not washing properly, smells like mold
I have a samsung WF306LAW/XAA and it also smells like mold. I found I had a small leak which turned into a large on over a long periond of time. The leak was in the guide water also known as the silver care kit. The bottom of the washer has foam wire and hose covers to soften the noise, they get wet and mildew. make sure you do't have a small leak and dry out the cavity.
Jul 28, 2010 | Kenmore Washing Machines
Machine cycles through heavy to light loads continually
I have the Oasis HE 27082604 and have been having the same problem as everyone else is. I called Sears and other numbers and they said it was beyond their control and this washer wasnt recalled. So they wouldnt honor it. Does anyone have a recall number. They say there is no recall on these washers.
Mar 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
