Question about Ovens
HOw to start the diagnostic mode on Thermador oven
Model C271ZS 27 purchased 2005
4 Suggested Answers
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
huuum
  • 750 Answers
SOURCE: Thermador CMT227N
Hello air pro AC,
Welcome
You said, In the microwave mode - immediate clicking noise at start up. Oven, Convect modes work
Oh there are many things to check here.
1.look at the wheel base turning the plate that rotates your food for crumbs or sticking pieces of food.
2.check that the wheels are not worn down.
3.There can be a problem in the bearing, or linkage, or motor that spins the plate!
Do you get a error code?
How old is it ?
huuum
Waiting your response!
Posted on Oct 17, 2008
mc1bean
  • 3053 Answers
SOURCE: oven is 50 degrees out of calibration and will not
Hello, kadid
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
For Thermador SC301 ZC/01 built-in oven, should I buy 27 or 30 inch baking element?
You buy the one and only the one the manufacturer supplies for that model. Switching will cause problems with cooking and electronics in the immediate future. Order ONLY through a supplier that has the ability to look up the proper part for you.
Automatic Appliance Parts is one, 800.323.027, call them for the part and save yourself headaches.
Jan 26, 2015 | Thermador Ovens
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
Nov 03, 2011 | Thermador C302U Electric Double Oven
How do i self clean
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following products. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: Thermador� Built-In Ovens
Units: About 37,000 (42,000 built-in ovens were previously recalled in June 2007)
Manufacturer: BSH Home Appliances Corp., of Huntington Beach, Calif.
Hazard: The ovens can have gaps in the insulation where overheating can occur and when used in the self-cleaning mode it can cause nearby cabinets to catch fire. This poses a fire hazard to consumers.
Incidents/Injuries: BSH Home Appliances has received three additional reports of incidents, including two that resulted in fires that damaged surrounding cabinets. No injuries have been reported.
Description: The recall involves Thermador Brand built-in double ovens with model numbers C272B, C302B, SEC272,C301U, SEC302, SECD272 and SECD302 and serial numbers between FD8403 through FD8701. Model and serial numbers are located on the underside of the control panel.
Sold at: Appliance and specialty stores nationwide from June 2004 through July 2007 for between $3,000 and $4,400.
Manufactured in: United States
Remedy: Consumers should immediately stop using the oven�s self-cleaning mode and contact the firm to schedule an inspection and free repair, if necessary.
Consumer Contact: For additional information, contact Thermador at (800) 701-5230 24 hours/day, 7 days/week, or visit the firm�s Web site at www.thermador.com
Dec 05, 2010 | Thermador C301U Electric Single Oven
CAN NOT LOCATE THERMADOR MODEL CMT231WC-1 DOUBLE ELECTRIC OVEN INSTALLATION MANUAL
I've had a good search and the link below is the best I can find, the other alternative is to contact Thermador and see if you can purchase a hard copy.
http://www.thermador-eshop.com/eshop(bD1lbiZjPTAwOQ==)/thermador/us/prodp.htm?prod=CMT231(00)&ESHOPTYPE=S
Hope this helps for now.
All the best.
Aug 20, 2010 | Ovens
I bought a used 27" Thermadore double oven off Craigslist. (Loves me some Craigslist.) SS, convection, electric. Sticker on side indicates it was manufactured in 2001. I can't find the tag with model...
If Thermador kept the tag information in the same place, look at the bottom of or just below the control panel (front left hand side of the control panel (when facing the oven) where the cabinet curves).
The oven cleaners can damage the finish and parts of the self-clean oven. The damage may cause the oven to fail sooner than it would otherwise.
If you have a small spill that you want to clean without using the self-clean cycle, on a painted surface, use soapy water or Fantastick or Formula 409 applied to a clean sponge or paper towel and then wipe clean. If the spill is on a porcelain surface, wait until the oven is cool and use Bon-Ami or Soft Scrub on a clean sponge. Then rinse clean. For stubborn dirt, use a soap filled pad.
I hope this helps.
(Thermador has manuals on their website: http://www.thermador.com/SupportCenter/DocumentDisplay.aspx?menu_id=27&menulevel=0302&cat_id=687 )
Aug 05, 2010 | Ovens
Thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Jan 13, 2009 | Thermador C302U Electric Double Oven
Thermador CMT227N
Hello air pro AC,
Welcome
How old is it ?
huuum
Oct 17, 2008 | Thermador Ovens
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
