Question about Vizio Televison & Video
I bought 2 Unisar TV Listeners and set them up on my Sanyo and Vizio TV's. They both work on the vizio but not the Sanyo Do I need any adapter of some sort for the Sanyo TV?
SOURCE: code for Vizio tv
Go to the VIZIO site - they post codes. Try these for Cox:
0030 or 1758 or 0178
Dan
Posted on Dec 11, 2007
salsaurbana
  • 56 Answers
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Posted on Nov 19, 2008
SOURCE: Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Posted on Dec 29, 2008
Start with code 19. If it does not work try all the Daewoo codes..
Posted on Jan 09, 2010
SOURCE: Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Posted on Jan 18, 2010
How do I connect Vizo soundbar to Sayno flat screen Tv
Must have compatible inter connect; some Sanyo sets don't have the optical digital output or wireless connecting capability. That's how they keep their prices down low. Sanyo is a good brand but don't have lots of features and I/O stuff on some sets.
Dec 11, 2014 | Vizio Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Help! My not so electronically inclined husband has a Sanyo stereo system (came with the marriage, the manual did not)..we just bought a HD Vizio, I want to hook it up to the Sanyo, but no manual and he...
I personally do not follow the route-everything-through-the-receiver model. Sound - ABSOLUTELY; Video? Nah.
Is the Sanyo a SOURCE of sound? More likely it's just the light show at the end of the Cable Box, which IS a source of high-end audio. Treat it as any digital source like a CD player for audio.
The Sanyo NEEDS a basic video output to the TV so you can use the Sanyo's menus. The Vizio NEEDS basic audio from the Cable Box (for watching news and other lo-fi content); and the absolute BEST video from everything.
As far as manuals for the Sanyo go, a model number would help.
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mar 30, 2011 | Audio Players & Recorders
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Vizio 32/DirecTV - slow to change channels
Some TVs switch faster than others, plain and simple. I went from a Sony LED to a Sanyo LCD TV and there's a world of difference between the two in terms of how quickly each powers on and how fast one channel goes to the next after inputting the channel number on the respective remotes. The Sony is lightening fast compared to the Sanyo. I have a Phillips LCD in a bedroom that takes a long time as well, like the Sanyo. Personally I think you get speed with either the LED (over the LCD) and/or it's related to the quality and associated price you've paid.
Dec 09, 2009 | Vizio L32 32 in. LCD HDTV
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Jan 14, 2009 | Panasonic TC-32LX85 LCD TV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
