Question about Snapper Garden
Snapper string trimmer throttle starts but will not idle down runs like throttle is open can not get engine to idle or run at low rpms
    Master:
  • 923 Answers
Perhaps something is stuck in the throttle actuator, or perhaps the carburetor is loose. Check the bolts or screws that hold it on the motor block, but if they are very loose, you probably should replace the gasket(s)!
Posted on Apr 19, 2017
The trimmer starts like a dream but only runs with choke on
sounds like the carb needs to be removed and cleaned. It the chunk of metal that has the fuel line going to it on top of the engine.
Use a phillip screwdriver and possible a small ratchet to break it down and clean it thuroghly with gasoline.
After you get it back together and have cleaned it up as much as possible, crack her up with full choke again. this time though, allow it to run and barely ramp up the rpms enough to give it a little lug. When the engine seems to begin losing power, (these adjustments should be as small as possible until you get her running smooth) dial the choke back just enough to ramp up the rpms. This will probably take a few tries, but most definately should work in your case.
Once the trimmer is running smooth with the choke off you will be good to go.
Many times our trimmers and other 2cycle engines dont get the proper attention to keep them running up to par. Take the time to consider the unique properties of your tools to determine any possible future repair. Anytime you have and engine that burns a home mixed fuel there will be the risk of trash in the fuel system
GOOD LUCK AND PLS RATE THIS POST!!!! :D
Jun 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Pro PPB250E trimmer won't idle
clean and repair carb, make sure the mounting gasket is ok. and does not have a vacuum leak.
May 28, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Engine runs then quits
You may have a small air leak at the carb, sometimes found at the bulb primer. This allows the engine to stop picking up fuel due to sucking air into the fuel line. If you re-prime, it will run again for a short period?
Apr 15, 2010 | Garden
Engine will not run wide open
you need to make sure there is not a fuel restriction first check the fuel filter, then the lines. If these seem ok then adjust the High speed rpm, there should be two adjusters one for High speed one for low speed(when the throttle is fully engaged.Do small adjustments at a time.
Jun 14, 2009 | Garden
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
High / low speed jets both turned into base completely, how many rotations out before fine tuning for performabce.
Hello:
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Garden
I need a manual for a homelite gas hedge trimmer HT-19 I need the factory settings for the carb. bottom out screw turn out 1 1/4 turn? Have to hold throttle wide open to run.
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Garden
Hard to start
Hello judy_keough2:
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Need to adjust fuel and air mix to start trimmer.
Hello gwturley201:
I am Including the Carburetor Adjustment File Also.
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holding it to the Carburetor Body.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade or for Chainsaws and Trimmers; they Operate without Bogging Down. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Do not have basic setting for 2 speed jet so engine revs up and down instead of constant speed.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/2 or 1 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog Down Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
Good Luck
Respectfully
jbridger (John)
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
54 people viewed this question
Top Snapper Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
mburke3
Are you a Snapper Garden Expert? Answer questions, earn points and help others
