Question about Emerson Pool & Spa
How hard is it to change the motor out in an Emerson pool pump model k63cxese4793 (Challenger Pyrex triton)
    Top Expert:
  • Emerson Master
  • 8,673 Answers
Less hassle to replace whole pump if motor overheating ruining seals and possible distortion of plastic housing might leak
Posted on Mar 24, 2018
  • Emerson Master
  • 1,383 Answers
NOT tat bad, (first x2) shut breaker off next take off the stainless steel band, pull motor and seal plate back from plumbing portion use wrench on back of the shaft of the motor, impeller screws off to the left, take out 4 9/16 bolts that attach the motor to the seal plate, give seal plate a tug and it should separate from the motor. use new seals especially the shaft seal (the one w/the spring in it) and put it back together. tap on the SS band this allows it to evenly pull up around the tank body lastly FILL PUMP (prime) with water.
or search for your LOCAL POOL PUMP MOTOR REPAIR GUY. and ask about installing the motor on the seal plate.
I charge $20 and it includes the shaft seal (most pumps)
How hard is it to change the motor out in an Emers - greasy127-5wza5llwn2qwnlqvdjcvdeqf-4-0.jpg
Posted on Jun 07, 2017
john224
  • 1378 Answers
SOURCE: Describe your AO Smith 1.5hp Pool Pump Motor 2
According to our Emerson parts dealer, parts for that motor and the motor itself are obsolete. They could not provide a part number to search for or an equal part either. We can quote you a new BN34 if you wish to contact us through www.arrowpools.net.
Posted on Aug 21, 2009
  • 4 Answers
SOURCE: motor feels excessively hot after running for only
It's sounds normal the motor will get hot. If it were overheating it should automatically shut down wait to cool off and restart.
Posted on Sep 12, 2009
  • 10 Answers
SOURCE: disassemble pentair challenger pool pump
remove the 3 screws on the front with 1/4 inch nut driver remove the diffuser and mounting plate remove cap covering the bolt head on the back of the motor hold the motor shaft with an ajustable wrench or vicegrips turn the impeller counter clockwise it should only be hand tight unscrew the impeller
Posted on Sep 01, 2010
  • 4350 Answers
SOURCE: I have an Emerson 1081 Pool Pump Motor , every
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
Posted on Oct 20, 2010
john224
  • 1378 Answers
SOURCE: Wiring up Emerson 1081 pool pump. Using 230V. Is
Thank you for posting your question here on Fixya.com.
There is no polarity associated with the leads in an AC system. You simply have 2 hot wires and you can hook either one to either Line 1 or Line 2. Motor rotation is not dictated by the connection arrangement of these leads. Ground the motor with the grounding wire and again with the bond wire if one is present.
You can remove the riser that is positioned under the motor to allow for a 56 size stator to fit in place of the 48 size stator the original Hayward (AOSmith) motor was.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 02, 2010
Motor hums but won't kick on
motor high limits tripping defective motor replace motor or whole pump
Jun 14, 2014 | Pentair 1 HP Challenger Pump
Show picture how to replace pot gasket in emerson pump s55nxnpk-7243
Emerson - to my knowledge, does not make pool/spa Pumps!
Just motors.
Then pump manufacturers utilize Emerson as a 3rd party vendor to supply them with a motor for their Wet End. Then when their Wet End is installed onto a motor, like Emersons, then is it called a Pump!
make and model of your pump?
Feb 26, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
T55cxcas-1179
Provide make and model of your pool pump. Emerson is a motor manufacturer. Not pumps.
Jan 12, 2014 | Emerson Pool & Spa
Emerson pool pump model k63cxesf-4793
Emerson is the manufacturer of the actual motor, not the entire pump. Many manufacturers use Emerson motors as a base for their pump systems,
You need to contact Emerson Motors USA for warranty info. Please have the "sticker" info on the pump motor available.
Apr 03, 2013 | Emerson Pool & Spa
We have a challenger pump that operates a waterfall connected with our pool. The motor on the pump burned out. Can the motor be replaced without changing out the whole pump?
Yes, it is a rather common motor available thru any local pool store and also local electric motor repair shops, whose prices are likely a little lower. A common part number for it is USQ1152 from A.O. Smith. Depending on where you shop, it may have a different number but will otherwise fit without any trouble.
John
Jan 14, 2010 | Pentair Challenger High Head 1.5 Hp Pump...
I have a challenger pool pump that has a very high pitch sound
The motor bearings are probably starting to fail. If you winterize the pool I would take the motor portion off the pump and have a local electric motor repair shop look at it. A simple bearing change and new pump seal would run $50 or less at most places. If not, shock the pool and run the pump overnight to balance the water and then pull the motor for the repair. It will probably only take a day or so for it to be completed.
Aug 30, 2009 | Pentair Challenger 1 1/2 Hp In Ground Pool...
Aug 20, 2009 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My challenger 3/4 pump has started to sound louder and louder.
Replace the motor bearings before they fail completely and ruin the motor.
Jun 07, 2009 | Pentair Challenger 3/4 Hp In Ground Pool...
Pool & Spa Logo
83 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
