SANSUI SAN0669 trying to hook up audio tv and dvd to home theatre system with red and white audio cables
  • 1 more comment
  • Anonymous Jun 09, 2008
    trying to connect system to phillips dvd payer, not having any luck getting all the speakers to work at the same time. have even tried to cnnect to t.v and still having the same problem,either the sub will work or only the centre speaker, and then only one front speaker will work...
  • tozza Jun 10, 2008
    I've bought a sansui san0669 without cords, how do I hook it up to a stereo or vcr Thanks
  • RobSydney Aug 18, 2008
    I have also had exactly the same problem. Have now had remote control failure too.
    Does anyone have any idea how to obtain a new remote (I note that universal remotes of any brand don't seem to work!)
  • 138 Answers
I think you must change the settings and try it out! it will make a great change.
Posted on Dec 08, 2007
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
  • 82 Answers
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Posted on Feb 09, 2008
  • 105 Answers
SOURCE: I am trying to connect
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Posted on Apr 03, 2008
  • 5568 Answers
SOURCE: hooking up Coby Csp-94 Speaker to HDTV "no directions"
The green, black and beige cable is non-standard and proprietary meaning that Coby has defined their purpose which hopefully is described in your user guide. It would be worth a few dollars to buy the properly color-coded cables to uncomplicate your setup. Buy cables (or cable sets) that have the same color coding as your TV jacks along with the cable suggested below.
There are several ways to connect to an HDTV system and these are normally standard as previously described.
The red and white are for right and left channels and it isn't uncommon to see a three cnductor cable with one not connected since one of the methods of connection is to supply audio via two cables, video (composite) via a 3rd which is plugged into a corresponding jack, normally colored yellow. Audio cables aren't really required to carry the mix of much higher frequencies of composite video.
If you have the following connectors, try this:
- S-Video (this does not contain any audio information and requires an S-Video cable) - Right (red) and left (white) audio paths.    The S-Video connection provides a better signal that gives you a noticeably sharper picture. This setup is selected from the TV's input source menu.
Posted on Sep 08, 2008
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
The tv is a Sansui HDLCD1909A I can't find a
The only audio output on the HDLCD1908 and 1909 series of Sansui tv's is the coaxial audio out jack. It only works when the tv is tuned to a digital station on the tv's internal tuner. If this won't work for you try getting your audio from your cable or sat box, etc. I hope this helps you.
Jun 24, 2010 | Sansui HDLCD1908 19 in. LCD TV
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Hooking up audio video to cable box with home theatre
From Cable Box to Input on DVD Player, from DVD Player Out, to TV in, from TV Audio Out to Home Theater Audio In.
That should work.
Will have to have the VCR on to watch cable. Plus make sure that you use A/V cables as much as possible. Coax works ok, but not as good as R/W/Y.
Feb 13, 2009 | Panasonic Home Theater System System
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
We have a samsung ht-z515 home theater system and a new samsung ln-t4669f hd tv and I'm trying to hook up the system so we can hear it through the speakers. We are on Verizon Fios and I bought a Fiber...
Make sure the TV is set to output audio to the digital optical port. Then make sure you have selected the proper output mode on the home theatre. Unplug the optical cable from the back of the home theatre and see if the red laser is on (don't shine it in your eyes! :))
Sep 03, 2008 | Televison & Video
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
144 people viewed this question
