Question about Lexmark X125 All-In-One InkJet Printer
Change color ink message won't clear from machine
I just changed the color ink cartridge on my LEXMARK X125 but the change color ink message will not clear from machine, even after hitting the start/yes button and unplugging the machine.
  • 24 Answers
Look for the all in one icon, then choose the change cartridges, say to pc that are news cartridges, that will raise de ink level.
Posted on Jul 24, 2009
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
How do i change mu ink cartage
go to following link then go to basic then maintaining the cartridges http://www.lexmark.com/publications/pdfs/x125/eng/enogwin.pdf
Nov 28, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark x125 system error after installing new inks
All cartridge installation and level reporting is done through the printer itself, not the software. You should ensure the X125 has the cartridges installed in stand alone mode first. To do so, open the lid and remove the cartridges. Then unplug the power cord for one minute. Reinsert the cartridges, connect the power cord and close the lid. When the lid is closed, the display will ask you if "New" or "Old" cartridges were installed. If new, align the cartridges, if asked to do so. If this still presents you with a "Change Cartridge" message or something similar, please try a different cartridge.
Sep 30, 2009 | Lexmark X125 All-In-One InkJet Printer
Color Cartridge Has Stopped Working...Lexmark Z45 Printer
i think this a firmware issue of the printer..
try to flash a new compatible firmware .
May 12, 2009 | Lexmark Color Z45 InkJet
Get message error change cartriges the cartriges are new
Apr 22, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
My fax machine keeps saying change balck ink even after I did
You need to connect it to your computer and go to the properties.  Select install new cartridge.
Feb 02, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
Lexmark 125 Prints Labels with color cartridge
I kicked the **** out of it and it started to print. I don't recommend it if you are afraid you may damage the electronics. The way I saw I spent damn near 70 dollars on some useless print cartidges nothing was wrong with them. The error message kept saying ADD CARTRIDGES. Anyway I'm thinking about a new printer anyhow.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
Flashing error message
i have the same issue... i tried a few things, including resetting the printer (powering it off for 30+ sec and turning it back on) cleaning the nozzles on pc and manually... cleaning the connectors on the cartridge and cartridge caddy... all to no avail... a Lexmark rep told me I have a defective printer...
May 06, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Change all ink problem
1- powering off the printer and leaving it for 30 sec. then powering back on... test
2- power off, open the cage, move cartridge caddy to center to remove cartridges... clean cartridges nozzles with a damp cloth, clean cartridge connectors as well as cart caddy connectors with a soft cloth.. no water. re test by replacing the cartridges and powering on the printer.
if the operator still has the message. power of, try with 1 cartridge at a time, turn on printer and try to COPY any document...
if all of that is still failing, then as the Lexmark rep told me, i'm sorry for any inconvenience this brings you, you have a defective printer.
Mar 11, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
159 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
