Question about Vizio Televison & Video
No picture on a Vizio TV model E420i-AO. Tried resetting, have replaced main & power boards in the TV, still won't power on. Not even the small "power on" light will work. Any suggestions? Thanks!
ginko
  • 19396 Answers
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
Posted on May 04, 2009
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
SOURCE: Why won't my Samsung UN40D5005BF come on?
Lightning damage can do a # on LCD TV's. I've seen cases where it took out power supplies and main boards at the same time. I'm not one who likes to use the "shot gun" approach. You would need to get the set professionally diagnosed in my opinion. Where did you get the main board from?? Are you sure it is a working board?
Posted on Sep 02, 2012
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
Posted on Apr 25, 2013
My 42" Vizio model #E420i AO has a black bar across middle of it and up top left side. Tried adjusting back lite but didn't help. Is this the back lite or something else?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
If the set uses CCBL lamps for back-lighting, check all the lamps. A weak one may cause this.
Jan 15, 2017 | Vizio Televison & Video
My flat screen TV has a dark shadow in middle 3rd of screen the upper 3rd and bottom 3rd are nice and clear. Would this be LEDs starting to die?
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Sep 26, 2016 | Vizio 42 in. LCD TV
Sound but no picture. Vizio E470i-AO
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.....
Jul 18, 2016 | Vizio Televison & Video
I have a Vizio E420i-AO 42" TV. I have sound but no picture
Try to replace the capacitors in the power board. Sometime bad electrolytic capacitors can lead to such problems. May capacitors looks good. But you have to replace it .
If you wiah to get some more details about flat panel TV repair then check the following link.
http://electro-medical.blogspot.com/
Jul 08, 2016 | Vizio Televison & Video
What is wrong with a tv it has sound but no picture vizio model #E470i-ao
Apr 15, 2016 | Vizio Televison & Video
Vizio TV has sound but no picture
Dec 02, 2015 | Vizio Brand Original Remote for E320i-B0...
I replaced both boards on my vizio E420i-AO and I still have nothing when I turn it on. What else can I do ?
Hi Dennis, since you have replaced boards on your TV and still not working.. Check the link below to find additional info on why your TV still doesn't work. Watch the video provided on the link:
http://www.shopjimmy.com/lg-lc420dug-jfr1-led-strips-10-strips-1-board.htm
Oct 06, 2015 | Vizio Televison & Video
How to fix my led screen, it has no picture i have purchase and replace the led driver.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Command voltage to switch ON the LED driver section, should come from the main board's system control section. It do not come now.
Aug 07, 2015 | Vizio Smart TV keyboard remote control for...
Vizio e470i-ao won' turn on, power supply board replaced still no picture or sound, led power on indicator light comes on momentarily then goes out?
Power ON signal voltage should come from the main board to power regulator board. It does not come now. Check for the reason. Probably, the main board will have the fault. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 23, 2015 | Vizio Televison & Video
Televison & Video Logo
44 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
