My dryer (Zanussi ZDE47100W) stalls when heavier loads in drum. This is much less than the wet laundry weight that it coped with when new.
  • Washing Mach... Master
  • 2,342 Answers
Try a new drive belt
Posted on Apr 19, 2017
The drum on my Maytag dyer model MDE308DAYW, will not turn with a heavy load why?
Because of one of the following
The belt has stretched (new belt)
The belt is slipping (new belt and clean drum)
The Spring on the idler pulley tensioner is weak. (Replace spring and lubricate pulley)
Dec 08, 2015 | Dryers
Zanussi zde47100w what else can a e62 error be
E62, is a faulty heater unit, faulty wiring or faulty main control board. You have already changed the heater unit so check all wiring. If OK, then you will probably be looking at a new control board.
Apr 08, 2015 | Washing Machines
My Zanussi TCE7124W is not running cycles properly and the clothes are still wet at the end of a run
The filters are clogged.
• The condenser is clogged.
• The water reservoir is full.
• The selected cycle is not suitable for the laundry.
• Insufficient drying time.
• The laundry has not been spun properly.
• The low-temperature function selected.
• Excessive laundry load.
• The dryer is not correctly installed.
Also, check the heater elements.
For the movement, check the drive belt has become worn or snapped. To test your tumble dryer's drive belt, we recommend you manually spin the drum. If it is stiff and difficult to move, the drive belt is ok, if it is easy to move, there's a good chance the drive belt is the fault.
Nov 02, 2017 | Zanussi Washing Machines
Hotpoint wf240 - jumps around when spinning laundry - the problem seems to be the drum turns too fast before the spin so the laundry is balled up before the spin - has anyone any ideas on how to fix...
Ensure that your machine is on a level surface with equal weight on the four legs. There are adjustable feet on these machines so as to balance the load on each support. These supports are adjustable by twisting them clockwise/anti-clockwise to get the correct balance.
Jan 05, 2011 | Hotpoint Washing Machines
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
I have a GE dryer (DCVH660EHOWW) that makes a squeeking sound when running (louder when the wet, and heavier, load of laundry is first put in). I'm assuming it is either bearings that hold the drum or a...
Check belt tension Pulley through inspection plate at back of
dryer.
Oil it if you can get to it.
please rate me if this was helpful
Thanks
Leo Ponder
imufo2@sbcglobal.net
Jul 31, 2010 | Dryers
Spin cycle won't work
this is the spin balance protection system cutting in.
take out some of the heavier items in the load and try the spin cycle again.
Mar 28, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Wet towels & blankets stacked on working dryer
This won't affect drying time unless the load is so heavy it causes the cabinet to warp and disturb the door seal. If you haven't had any problem with this so far you can probably keep doing it. (The machine is designed to support the weight of a wet load in the drum, and should have some safety margin. But why not invest in a roll-around laundry cart like you find at laundromats and keep the wet load there until the dryer is clear?) You might need to be more concerned about rust starting on the top of the cabinet if the enamel is scratched, since it's not usually subjected to wet loads being piled there. You should also check your vent pipe frequently to make sure it stays clear with all the drying you do. Clogged lint screens and vent pipes will definitely lengthen drying time.
Feb 18, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
My husband and I are building a new home with a second floor laundry room. We are very interested in purchasing a LG washer (WM2688HWMA) and dryer (DLEX8377WM), but need strategies to keep the units...
hi As a safety device, a dryer usually has a door switch that activates the working .A dryer is simply a large drum into which wet laundry is loaded. A motor with pulleys -- connected by a series of belts -- turns the drum. Air heated by a gas heater or electric heating element is blown through the drum to dry the laundry. The temperature and speed of the drum are controlled by a series of thermostats operated from a timer device on the control panel of the dryer.
The control panels on the latest dishwashers can look intimidating. They're loaded with so many dials, push buttons, and other features that the machine looks too complex to repair. This is actually not the case. With the exception of the control panel, dishwashers haven't changed much in basic design over the last two decades.
Sep 12, 2008 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
