Question about Clarion Car Audio & Video
Clarion car stereo stays on for a few seconds and then shuts off I have to turn it back on and it shuts off
silly girl
  • 513 Answers
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Posted on Jan 24, 2006
  • 3 Answers
SOURCE: won't stay on
If you have the service manual there is a section that shows you how to get the protection mode history with the codes. You can also reset all of the protection from the service menu listed above. Be careful in doing so but have fun if your fed up with it not working.
Posted on Dec 05, 2008
SOURCE: Car will on stay running for a few seconds before shutting off
It could be that your fuel filter could be clogged. You can check this by doing a fuel pressure test. After it dies, all the sediment drops off the filter so when you start it back up it does run for a small amount of time but then gets clogged up again after you start it again because it picks up the sediment again. You might also want to check your ignition control module. But my guess it's something to do withing your fuel system somewhere
Posted on Sep 02, 2009
Hitachi-mex
  • 26 Answers
SOURCE: Receiver turns for a fews seconds then shuts down
Hi.
If the word "OVERLOAD" is in your display, we have a bad channel.
But if only turn off, and the standby led is on all the time, you need change a couple of resistor of 10 Ohms at 2 Watts in main board. But you need disassamble a must all the amplifier. A lot of work, but cheap part.
Best regards.
Posted on Oct 23, 2009
SOURCE: SECURITY CODE NEEDED FOR CLARION CAR STEREO
www.radio-code.com/ -
www.radio-code.com/UnlockManu.htm -
floodle.net/extra/ebayinfo/car_radio_decode.html -
Those should sort you out.
Posted on Mar 25, 2010
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
you need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Mar 24, 2014 | Clarion NX602 In-Dash Car GPS Navigation
Reset my clarion car stereo
There will be a small reset button on the faceplate or behind it when the faceplate is removed. Press it with the tip of a ballpoint pen while the ignition (car) is turned on.
Press and hold it for about 5 seconds.
Jan 30, 2011 | Clarion DXZ665MP CD Player
My new Clarion CMD6 stereo won't stay powered up.
If all power and ground are good to go then the unit needs to be fixed. Being that it is more likely to "see" moisture, it may have water shorting out the circuits.
Jul 03, 2009 | Car Audio & Video
Clarion DXZ385USB
the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
Check your Factory speaker locations for blown speakers or bare wires to metal.
Dec 28, 2008 | Clarion DXZ475MP CD Player
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
Nov 09, 2008 | Clarion DB538RMP CD Player
I NEED A FEW THINGS FOR MY CLARION STEREO
Go to pacparts.com and you will find any CLARION accessories
Dec 18, 2007 | Clarion DRX6375
Marine stereo (Aquatronics) Turns on and then shuts itself off
aquatronics model ms-1000 led display lights and nothing else
Aug 05, 2007 | Aquatronics AMS602WR Coaxial Car Speaker
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Car Audio & Video Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
