I have a Wobblelight that will not light. I hear the fan running, and I have replaced the bulb with one that I verified works. Any ideas? Thanks! Kevin
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Posted on Dec 25, 2006
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
  • 68 Answers
SOURCE: CFL bulbs won't work in ceiling fan?
they should all work. The only problem might be if they are connected via dimmer. Dimmers and CFL does not work together.
Posted on Mar 08, 2009
sk8er1707
  • 58 Answers
SOURCE: fan works lights dont
It's most likely that when the bulb burned out the electrical heat got to the socket causing the emergency shut down of the lights if you take of the light casing there should be a small switch next to one of the bulbs all you have to do is flick the switch, put back the casing and walla your lights should work (hopefully lol =])
Posted on Jun 06, 2009
parkeroc68
  • 18 Answers
SOURCE: Pentair PG 2000 light stopped working. Replaced
Have you replaced the ballast or did you just replace the capacitor? If you did not replace the ballast I would start there. Also if you have a multimeter check your bulb for continuity you may have gotten a bad bulb.
Posted on Jun 11, 2011
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
Blown bulb
Ideas? Yep. Shut down fan power at the source (fuse, breaker, etc.). Turn on fan power again. You should be back in operation
Jun 14, 2013 | Monte Carlo Manhattan Ceiling Fan
How much is a Lamp or a bulb replacement cost?
They commonly run from 99 - 249 on average. Sites such as www.TVRepairKits.com usually stock them.
Apr 24, 2013 | Panasonic Televison & Video
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Pentair PG 2000 light stopped working. Replaced metal halide bulb, worked for a few hours then stopped working and wouldnt come back on. Replaced capacitor, but light still doesn't work. Have verified...
Jun 11, 2011 | Home
Been following everyone's advice checking
I would start suspecting a DMD board
Aug 01, 2009 | Televison & Video
Mar 08, 2009 | IBM ThinkPad R50e Notebook
Hunter ceiling fan
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
