Question about LG Dryers
Lg dryer makes a rattling hoise when spinning. Can you troubleshoot this?
  • LG Master
  • 2,320 Answers
A coin or object in the fan housing. Or a bad drum wheel.
Posted on Apr 19, 2017
Lg dle2101w is making a loug hum and rattle but works fine
the hum is usually a bad motor? perhaps u hear what u think is a hum? the rattle can be due to bad bearings, for example transmission spin bearings, tub thrust washer bearing, loose belt or worn belt.
Mar 08, 2015 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
I have an LG dryer that has developed a rattle which seems to be coming from the bottom of the unit. Does anyone know what might cause this rattle and how to fix it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 02, 2011 | LG Dryers
Leaking from bottom on spin. also makes rattling
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 10, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer is making a rattling noise when in operation. Dryer is eight years old of so. Never heard this noise before.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Jun 13, 2010 | LG DLE2532W Electric Dryer
LG DLE 2516W dryer has internal vibrations. something is rattling or vibrating inside and makes a racket when it is spinning slow or fast. the dryer is level and the leveling feet are all adjusted.
Check and make sure the shipping screws were completely removed.
If they are still in place, even partially, the tub was most likely damaged.
Aug 09, 2009 | LG Dryers
When I turn on my dryer on it gives a rattling/vibrating noise.
There maybe a lot of lont build up in the blower wheel housing. Take off bottom panel and take apart the blower wheel house and check for any lint build up....if it check ok, your drum rollers maybe worn....try checkin the blower wheel housing...hope this helps
Aug 04, 2009 | LG DLE2516 Electric Dryer
Gaining access to the inside of LG DLE3777 dryer.
with dryer turned off remove exhaust tube look inside for change i suggest using some kind of glove otherwise if it inside you'll have go through the bottom
Feb 10, 2009 | LG DLE3777 Electric Dryer
Dryers Logo
51 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
