Question about The Audio Players & Recorders
Transmitter shuts off app 1 minute after switch on. When we pull the power cord and reconnect the red On-light reappears for 30 sec. Then in ever shorter time windows the transmitter shuts off.
We used different transformer with the 12 V output. The problem remains.
SOURCE: Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Posted on Nov 14, 2008
SOURCE: Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Posted on Dec 23, 2008
SOURCE: Power will shut down after few minutes when volume reaches 12
If you check at the back of your hi-fi, you'll see a projection at the top where the cooler fan is located. The most likely reason is that your fan is not working (as required). In this system, the fan is turned on automatically at high volumes >=10, because then, the amplifier starts to get a temperature rise and without proper cooling the system might fault.
Try check and see if at these high volumes the fan is running, if not, then that's what needs to be fixed. Alternatively you can try running an external fan to see if it will produce the desired cooling effect.
Posted on Jul 02, 2009
SOURCE: Fm transmitter
I need to know wish to know on what raadio station I have to set up my radio so then I could connect my i-pod
Posted on Nov 28, 2009
SOURCE: Alarm system won't shut off
I had this problem with my jeep, I had to have it towed home because the security would not let me start the car. I immediately jumped on my PC and found the solution. "Press your lock button, then go to the rear of your truck & unlock the hatch with your key".. You have to unlock THAT door with your key in order for it to shut off. Hope this was helpful, worked for me!
Posted on Feb 01, 2010
Often the flashing lihts of router go off and reappear again, but this causes problem in internet acess. What to do?
Is there a issue with the power jack being pulled? Try to replicate the problem by "wiggling" the power cord at the the AC jack in the rear of the Linksys. I have found this to be a issue if the cord and "brick" are hanging free, it pulls on the AC jack breaking the connector.
Dec 21, 2012 | Linksys Wireless-G WRT54G Router
Paper jam message but no jam seen. Have unplugged from computer and wall. Shut off x 20 minutes. Alarm light shuts off momentarily and then reappears with first printed page.
Paper can be jammed internally.
1) Turn off the printer and disconnect the power cord and USB cable.
2) Open the rear cover. Look for a jam or even little scraps of paper from a previous jam that may be obstructing the paper path.
3) On the front, remove the tray and look into this area. Make sure it is free of any obstructions.
4) Replace tray.
5) Reconnect the USB cable. Power ON.
I hope this helps!
Dec 24, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I am geting error 1102
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Disconnect the power cord from the electrical outlet.
3 Reconnect the power cord to the electrical outlet.
4 If the power button is not lit, press power button.
5 Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
4 If the power button is not lit, press the power button.
5
Reinsert the black (or photo) print cartridge.
6 If the error:
Reappears, replace the black (or photo) print cartridge with a new one.
Does not reappear, reinsert the color print cartridge.
7 If the error reappears, replace the color print cartridge with a new one.
Oct 16, 2008 | Lexmark Office Equipment & Supplies
Deskjet 940c
Shut down the PC. Pull the AC power cord from the printer out of the wall. Wait 30 secs. then plug the printer back in, then power up the PC, It should go back to normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 02, 2008 | HP DeskJet 940c InkJet Printer
2Wire Router will not power up.
If it is not getting any power at all,
only one of three things:
cord is fried/dead;
could be the outlet,
try something else in the same socket; or, the board in the ROUTER is dead.
Disconnect power cable WAIT FOR 20 sec and then reconnect it..Reset your router, ..To reset the router, the best way is to press and hold the reset button for 30 seconds, or to press the reset button for 60 seconds..and for first 20 sec hold the reset with the power cable connected and for the next 20 sec with out releasing the reset button disconnect the power cable and continue holding the restet button , and after 20 sec reconnect power back and then continue holding the reset for another 20 sec.. and then ncheck for the lights status ..
Try another power cord. Take it back to the store and have them exchange it or test it. They'll do that for free.
Dec 07, 2007 | 2wire (1000-400108-001) Router
27 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
