Question about GPS
My TomTom XL1 at times will not pick up gps signal. Note comes on and says lost GPS signal 2.4 min ago.
  • Gene Tuck May 11, 2010
    If it is mounted on your windshield with a suction cup you may have to move it lower. This puts it forward a bit so that it is out from under the roof, and it receives the signal better. If it has a folding antenna, make sure it is deployed correctly, or pulled out.
    Brigadier General:
  • 4,090 Answers
Your battery is beginning to fade. if you fully charge it before use asnd it does this regularly then replace the battery
Posted on Jul 26, 2009
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
NO GPS SIGNAL
hi go online and update automatic. it wil receive new info about satts an wil function like before. do this couple of times a year. good luck
Feb 04, 2010 | Tomtom ONE GPS Receiver
No gps signal with tomtom
Solution for No GPS Signal
To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays gray and one of the following messages is shown in the bottom right corner of the Driving View:
  • Waiting for a valid GPS signal
  • The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find your current position:
  • You use your TomTom device for the first time.
  • You haven't used your TomTom device for a longer time.
  • Your TomTom device has been relocated without using it (e.g. after traveling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open place without tall buildings or trees around you.
Once your TomTom device has located your current position, the Driving View is shown in full color and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster.
Flight mode
On devices with built-in GPRS connectivity, flight mode also disables your device’s GPS reception.
To switch flight mode off, tap Flight mode in the preferences menu and then select Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current position.
Try repositioning your device in your car; ideally, try to position it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your device from locating your current position. If this is the case in your vehicle, use the TomTom External Antenna Kit (available as an accessory).
Tip: As a reference, place your device outside your parked car to see if it can find your current position.
Reset your device
Reset your TomTom device. Click here to learn how to reset your device.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Feb 01, 2010 | Tomtom ONE GPS Receiver
My tom tom has lost gps help! all of a sudden half way through a journey my tom tom lost all GPS signal and wont pick up anything? is there anything i can do to get it back?
here are some tips on what to do ,To pinpoint your location, you need to get signals from at least 4 satellites. If you receive signals from less than 4 satellites or the signals are not strong enough, the Driving View stays grey and one of the following messages is shown in the bottom right corner of the Driving View:
  • Your TomTom device has been relocated without using it (e.g. after travelling by plane or train).
Once your TomTom device has located your current position, the Driving View is shown in full colour and shows your position on the map.
Tip: Most TomTom devices can use QuickGPSfix™ to locate your current position faster. Flight mode
Clear View
Reset your device
Aug 28, 2009 | Tomtom ONE GPS Receiver
I have a Tom Tom GPS and all of a sudden it says searching for satellite signal but never picks one up. Any suggestions?
  • Waiting for a valid GPS signal…
  • The GPS signal was lost … sec ago
Clear View
Make sure battery is fully charged before use
Reset your device
Jul 24, 2009 | Tomtom XL 330 Car GPS Receiver
No gignal on tomtom one xl
take it to the seller to have it reinstalled
Jul 04, 2009 | Tomtom One XL GPS Receiver
Tomtom keeps loosing GPS SIGNAL AND TAKES LONG TIME TO COME BACK
Plug in your tomtom and open my computer. Make note of the driver letter next to the tomtom symbol. Click Start, run (or search on vista or windows 7) and type in "CMD" without quotes and hit enter. a black window will open. type the letter you noted in my computer followed by a colon. Example: F: and press enter.
then type "chkdsk /f" without quotes and press enter. Answer yes to all the following prompts. once completed "takes less than a minute" type exit.
You can also try tomtom backup and then restore.
Apr 20, 2009 | Tomtom GO GPS Receiver
My tomtom keeps saying waiting for gps signal. was working perfectly, now wont pick up signal wherever we are
go to tomtom website ----> support ---->select product,
in the search box type in "lose signal",
click the "2. Updated - No GPS signal"
then follow instructions.
if it help rate the Solution Please
21/Apr/09
Apr 20, 2009 | GPS
Tom tom comes on but,no gps signal lost for hours.
hi you need to reset the unit at the back near the connection there is a small button that needs to be held down when holding the power button on for a few seconds. once you have done this turn it on and it will work fine
Feb 11, 2009 | Tomtom GO 910 GPS Receiver
GPS Logo
154 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
