Question about Dirt Devil Vacuums
My dirt devil featherlite is spraying water from the back pedal. Help
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil Featherlite Bagless Upright
Check the brush roll, are the bristles worn down? Check the belt also, if it is stretched, then it won't drive the brush roll like it should.
Posted on Jan 15, 2008
  • 126 Answers
SOURCE: Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
Posted on Jan 20, 2008
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: Got Dirt Devil Featherlite,keeps burning the belt
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 22, 2010
  • 508 Answers
SOURCE: My dirt devil featherlite's brush
Does the motor spin?
Posted on Oct 12, 2010
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Dirt Devil FeatherLite Belt
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Replacement FIlter for Dirt Devil CE6000
My filter fell apart on my dirt devil featherlite CE6000. I have only used this 4 times.Where can I find one? I have looked at several stores.
Sincerly,
Pennie Silverman
Oct 19, 2008 | Dirt Devil CE6000 Featherlite Wet/Dry...
Vacuums Logo
37 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
