Question about Microwave Ovens
How do you test a silicone rectifier and a 64v capacitor to find if they are good or no good
Not heating the goods in the microwave the light and power is on but not heating or cooking the goods
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Sep 11, 2009 | LG Microwave Ovens
We had a small fire caused by a metal sticker inside our microwave. Now the unit is heating items, but not as much as it should. Can this be fixed or do we need a new microwave?
Use extreme caution when working on microwave ovens. Even when unplugged, the high voltage capacitor can store up to 2,000 volts! discharge the capacitor before doing anything else inside the box.
This may be a bad magnetron. Ohm test between the magnetron terminals, should be less than 3 ohms. Test from magnetron terminal to ground, should be open.
* Defective HV capacitor. Test with capacitor meter or ohm meter.
* Defective control board. Test for power going to board. If exists, problem lies on board somewhere.
* HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
In general because of safety issues (very high voltage, even when unplugged), I would suggest you get a new one.
Good luck.
Aug 14, 2009 | Kenmore Microwave Ovens
Lg microwave will not heat at all
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Apr 28, 2009 | LG LTM9000 Microwave Oven
Everything works does not heat
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron.
Regarding parts, your model number did not return any result, contact the seller here to purchase parts. (here in UK).If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron.
Apr 27, 2009 | General Electric Microwave Oven
My hotpoint rvm1425 is not heating anything up
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Mar 07, 2009 | Hotpoint RVM1425 Microwave Oven
Micro wave works but do not heat up the contens model koc 970t
Mar 04, 2009 | Daewoo KOC-925T Microwave Oven
Not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Feb 22, 2009 | Goldstar MV-1526 Microwave Oven
My oven does not heat but fan runs 20-30 and then quits
Jan 20, 2009 | Panasonic NN-S543BFW Microwave Oven
Amana cmax microwave
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Nov 29, 2008 | Amana HDC21 Microwave Oven
Not heating
Oct 28, 2008 | Whirlpool MH1141XM Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
