Question about Tablets & eReaders
I'm on my iPad right now, but I also have a phone, and a few days ago I changed the passcode to a password, but now I can't remember what it was! I've tried all the passwords I'd usually do, but no DX
  • 60 Answers
SOURCE: m4-s435 bios password removal
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Jun 08, 2010
  • 59 Answers
SOURCE: im trying to unlock the home screen of my ipad, i
Unfortunately, you're a bit stuck. The only way of removing a passcode without knowing it is to restore from an iPad backup when the passcode wasn't applied.
My advice would be to take it to an Apple Store, and explain the situation. They're always very helpful, and may be able to do something about it.
Hope that helped!
Posted on Mar 06, 2011
  • 1099 Answers
SOURCE: cant remember my passcode for my ipad
plug it into the original computer that you set it up with and through itunes you will be able to reset it. Once the ipod appears under devices click on the restore button it will indicate that you can restore settings etc. If it is not the original computer that you are using you will be able to reset it but will lose the information on it. Hope this helps.
Posted on Nov 22, 2011
SOURCE: Unable to rember my password
You can't access your ipad, or an ebook account,can you please provide more info about this issue?!
Posted on Nov 29, 2011
kitty22cat44
  • 48 Answers
SOURCE: forgot pass code to open tablet
i dont know of any way to do this without a factory reset. first shut down you tablet. then start it up in recovery(hold power + volume down). and last use volume buttons to scroll down to factory reset
Posted on Dec 07, 2014
Forgot apple id and password for my ipad
I would try to login to on apple's site first to remember I'd and password or passcode
Also you can reset it a few ways.
Have you synced it with a computer andnitunes which would allow you to back it up
See
Aug 19, 2017 | Apple Tablets & eReaders
How to lock iPad
https://www.techwalla.com/articles/how-to-lock-an-ipad
Locking your iPad requires entering a four-digit pin every time you turn on your device.
Step 1
Select the "Settings" icon from the home screen.
Step 2
Tap the "General" tab on the left side of the screen.
Step 3
Hit "Passcode Lock" on the right side of the screen.
Step 4
Select the "Turn Passcode On" option at the top of the screen. You also can elect to change your password and when it is required.
Step 5
Enter in a four-digit pin that will act as your password.
Step 6
Select "Erase Data" if you would like extra security. This option will erase all data on your iPad if the incorrect password is entered 10 times in a row. You should carefully consider this option because it can be quite risky, especially if you tend to forget passwords.
Feb 19, 2017 | Apple iPad Tablets & eReaders
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Nov 23, 2016 | Apple iPad Tablets & eReaders
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Forgot iPad pasword. After a few try, iPad is disabled. How to get password recovery?
You can't. You will have to connect it to a computer with iTunes, sign in to you Apple account, back up your data and then do a Factory Reset which clears all the data off it. After resetting, go through the wizard to set it up and then restore the data.
If you tried to enter 10 times or more, the SIM card, (if you use it for calls) will be disabled and you will need a new one from you cellphone carrier.
The information I have given you is confirmed in this article. If there were some easy way to bypass or recover a password, it would lack the security it was designed to do. It is only 4 numbers for heavens sake and you are using it multiple times a day! I use the last 4 digits of a memorable phone number. You can also do pattern repeats, left hand side of key pad 1,4,1,4. Right hand side of key pad 3,6,3,6.
Most enquiries here are from people who have actually found an iPad or have a stolen one, so tutoring about passcodes is useless, but I have given the info to you :>)
How to Fix iPad When Passcode Has Disabled It
Jan 24, 2016 | Tablets & eReaders
I have forgotten my googlemail password. How do I recover my email?
Having trouble signing in
Follow the instructions by this link; to recover your gmail password.
Be very careful when answering.
Gopakumar Gopalan Google
Feb 15, 2015 | Apple iPad 2 Wifi 16GB
Unlock passcode ipad
Did you have find my iPhone turned on? If you did you could have erased your iPad that would remove the pass code that is on there now
Aug 28, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How to change the password ?
1.go to settings app.
2.go to passcode.
3.type old passcode.
4.select change passcode(2nd option from top)
5.change the password.
thanking you.
Jun 17, 2014 | Apple iPad Mini
Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Apr 03, 2013 | Apple iPad Tablets & eReaders
Tablets & eReaders Logo
32 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
