Question about LG Televison & Video
I have a LG 42LV5500-UA LED tv with a black screen. Power light comes on but that is it. Any ideas on what board needs to be replaced? right in the middle of a program went black.
    Top Expert:
  • LG Master
  • 75,591 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 19, 2017
Shuttle83
  • 1139 Answers
SOURCE: black screen
This denotes a power supply issue. I would venture to say that it is the part of the supply that controls the plasma ignitor if this is a plasma TV or if this is an LCD screen it is called the back-light and inverter circuit. The power supply board would be the chief culprit in this case.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 21, 2008
SOURCE: Zenith TV has a big black box in the middle of the screen.
After reading other postings, we figured out that it was the caption box, went to menu and turned it off.
Thanks for the great site, we wouldn't have figured it out without it !
Jen
Posted on Nov 16, 2008
  • 458 Answers
SOURCE: i have a 42
The fuse you have replaced would have been on the sustain board, now that it clicks indicates a problem either with the control board or the sustain board. You would need to disconnect the connector from the power board to the Y-sustain board (left of power board) to check if the Vs & Va voltages are present, if so then the power supply will be working ok & the problem will be with the previously mention boards. There is the possibility that the plasma display screen could also be faulty.
Posted on Nov 06, 2009
  • 63 Answers
SOURCE: 50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Posted on Aug 03, 2010
jdvillanueva
  • 2098 Answers
SOURCE: 42"Plasma tv:TH-42PZ80U If the screen
Thanks for your initial troubleshooting, you've mentioned that the LED light on the right didn't lighted up, that is the SS board(AKA X-sustain board) which is already faulty that's why you've encountered that kind of symptoms. You have to replace this board to resolve the issue. Click it HERE for the replacement. Double check the part/board no of your board before ordering online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 23, 2011
My LG TV Model # 47LW6500-UA powers on (based on standby light turning from red to white), but screen is black, no sound, and negative flashlight test. Which part is most likely needing replacement? Main...
Going to need more information to help much, what do the various power board rails look like?...are they all good?
Going by the fact this set has had a lot of main board failures I'd lean towards that board but its just a guess without knowing some voltage measurements
Mar 11, 2018 | LG Televison & Video
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
Lg tv blink codes
Take the screen off connect power and watch LEDs if any don't flash its LEDs only needed to change faulty strip if they all flash its probably t con boards.
Oct 28, 2017 | LG Televison & Video
My LG 42LV5500 TV SET suddenly developed problem. All dead, black screen, no sound just power light. All PS voltages are correct.
I would agree with you on that. But it is your money. If the TV is old then replace it, if it is fairly new give it a try.
Jan 23, 2017 | LG Televison & Video
My LG 47LN5400-UA flatscreen has a black screen, everything works fine except black screen, when I shine flashlight on screen I can see full color picture, I have replaced the power supply/LED board.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Mar 14, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
Feb 22, 2016 | LG 42LS3400 42" Class FuHD 1080p LED LCD...
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
LG 42LV5500-UA LED TV turns on, but has no picture or sound
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Nov 04, 2015 | LG Televison & Video
Televison & Video Logo
90 people viewed this question
