Question about The Computers & Internet
I bought me a new big blue party speaker and charged it. But it won't turn on unless it's plugged in. But when I remove the charger then it shuts off and won't turn on unless charger is plugged in.
  • The Master
  • 9,267 Answers
The battery in it is junk
Posted on Apr 19, 2017
Indian Guru
  • 32 Answers
SOURCE: camera shut off during photos and will not turn back on
camera is not not recoginising the battery may there be a battery type mismatch or battery type is not provided correctly in the software of camera
Posted on Apr 25, 2007
SOURCE: My n30 can't charge, but turns on under charging
hi, I had the same problem so i checked some other forums. I then found the answer. While your acer is plugged in, hard reset it, this switch is on the bottom of the machine. Switch the hard reset thing to the left for five secs, then back to the right. The green light should start flashing! You just fixed you acer!
Posted on Sep 01, 2007
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
My phone shut off and won’t turn back on. I cannot remove the battery with the ZTE Max Z981
Check up battery is fully charged.or charging when charger in plugged in.If not charging check up charger working with some other phone .
If the battery is old enough replace battery or check up micro usb in phone thro' mechanic.
Oct 03, 2017 | ZTE Cell Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My H500 headset works or not?
May mean it is fully charged. Try long pressing big button until steady blue. Then have phone search.
Is your experience charging via wall charger different?
Mark
Motorola Support
Aug 31, 2014 | Motorola Mobility H500 Wireless Headset
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
Jan 11, 2013 | Kodak EASYSHARE M340 Digital Camera
Just bought this mp3 player and it will not turn on unless its plugged into the computer/charger.. No music and never been used till I opened it. Please Help!!!
The new player needs to be charged overnight for the player will work on the battery. You may need to do this a few times after the battery runs down.
Dec 14, 2012 | Hyun Won MobiBlu DAH-1500i (1 Gb MP3...
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
Dell Inspiron 6400 wont recognize new battery
Well often batteries from 3rd party manufacturer do not work in some laptops, see even the batteries have a "Chip" in them identifying them. Also sometimes these batteries are just no-good. or arrive flat, too flat to be charged up via the supplied charger. Anyway hopefully none of that applies and this will work. Now Turn PC OFF, put battery in unit. Now plug in wall unit, then plug into the PC, now leave the PC totally alone for at least 3 hours. Now the unit should work. Now how we tell where the problem lies is like this, Turn OFF, take out battery, now plug in the wall adapter, now the PC should work Fine like this. Now remove wall adapter, and insert the battery, the unit should go on this.. ONLY of course if charged. Now if when plugged in there are problems, it is more than likely, that indeed the battery is faulty, in some way.
These links below detail what steps to take to remedy any situation. The 2nd link is great.
http://www.dell.com/content/topics/global.aspx/batteries_sitelet/en/batteries_faq?c=us&l=en&cs=04
http://ftp1.us.dell.com/diags/R66243.htm
Mar 22, 2010 | Dell Inspiron 6400 Notebook
Palm TX won't power up without charger
Replace the Battery. This has either a faulty Or Discharging Battery.
Even brand new items can have a faulty battery, or charging system
i,d suggest returning for replacement or refund, if it,s new/warranted.
Mike @ compurepair.
Jun 11, 2009 | Palm TX Handheld
Computers & Internet Logo
173 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
