What does not support mean when it comes up on vizo tv
I CAN'T GET MY XBOX AND DVD TO WORK. IT SEEMS THE INPUT/OUTPUT STRIP IS NOT WORKING
First thing is to check the inputs with another device. If that works the you have a problem with your XBOX. If it doesn't work then you have a port problem on your TV which means you will most likely have to replace the input board. Make sure you have the proper input selected on your tv to match where your device is plugged into first though.
Jan 18, 2015 | Vizio Vizo VP503 50-inch Plasma HD...
TV fell and now only have black and white picture No color.
if you were using a straight coax connection you might want to try HDMI, on a Cable or sat box or if you are using component connections make sure they're all color coordinated. just because one input may be damaged doesn't mean other inputs are damaged try using a Blu ray player you know is good, checking different types of connectors and different inputs. If you get the same results off all inputs then the tv has sustained damage, might want to check prices at Walmart cuz it ain't gonna be worth it to have it fixed
May 19, 2014 | Vizio L37 Television
Vizo 47 in TV
Start by testing the voltages coming off the power board. Cycling is sometimes an inverter board or a fluorescent tube or a connection to a fluorescent tube.
Jan 17, 2014 | Vizio SV472XVT 47 in. LCD HDTV
Vizo tv comes on with white screen then shuts off
screen should be black with a dim back light than go to video you may have a short in the panel
Jan 31, 2013 | Vizio VA220E LCD TV
I have a LG 55" smart TV and can not get the sound
get into your setting on your tv (menu) and click on the audio and make sure the speakers are in off position.
Aug 20, 2011 | Vizio VSB210WS Soundbar
Can i get my Samsung remote AH59-02131J to control my vizo tv
As this remote was meant for a specific TV it will not work with your Vizo TV. Sorry for the bad news. Universal remotes can be cheap though and an easy fix.
May 05, 2011 | Samsung AH59-02131 Remote Control
I HAVE A VIZO TV 42 INCH) MY DOG ATE MY REMOTE THAT CAME WITH IT,THATS WHY I BOUGHT A VIZO UNIVERSAL REMOTE.BUT I LOST DIRECTIONS AND CODES,CAN YOU PLEASE HELP.
Find the model number on the back of the VIZIO remote control.
Go to the link below and enter the model number in the SEARCH BY MODEL NUMBER space provided or look for it in the scroll down SELECT YOUR PRODUCT menu.
http://www.vizio.com/support/
You should see a picture of your product and underneath it a small grey tab marked SUPPORT about halfway down the page.
From there you should be able to safely download a copy of the USER'S MANUAL which will contain the codes for your TV. Just click on the user manual link highlighted in red.
While you are there you can also download a copy of your TV's user manual if you don't still have it. The tv's model number will be on a sticker on the back of the set.
Good luck, hope this helps. Keep us up to date on your progress.
Jan 21, 2011 | Vizio 42 in. LCD TV
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
