Question about Eureka Vacuums
Where are the screws located on the Eureka Endeavor vacuum?
I need help to locate the belt on the vacuum please
flip the vacuum upside down and take cover off might need a phillips screw driver belt should be there on the brush roll once you remove the lid
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
How do I change the belt on Eureka Pet Pal
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Nov 25, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
How do you change the belt on a Eureka Altima and where is it located.
hi,
Just to get to the belt, you will have to remove 2 or 3 screws. All of which are located in the top cover. one on the left and right of the machine as your looking at it. The third screw if it is there, will be between the body and the hose near the back of the machine.
once you have the top cover off, you will see everything below, including the sticker on how to change the belt. It will be a black and yellow sticker. One tip tho, when you do get the brush roller out, take the ends off and clean off any hair/etc that you may find there.
Good luck.
Nov 14, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
How do you change a motor for a eureka model 8851
All of these vacuums capture the motor assembly between two plastic case halves, or are held in place by a band. Take out the phillips screws (sometimes the screws are under decorative plugs to hide them) and carefully pull one half off. You'll have a lot of taking apart to do, but if you actually got a replacement motor, it will be worth it.
Nov 25, 2009 | Eureka Capture Upright Vacuum Vacuum
Spray button doesn't function on Eureka Atlantis.No water spray.
should be mechanical, torx screws are easy to remove with a torx screw driver
Aug 05, 2009 | Eureka Atlantis 2595A Upright Wet/Dry...
I HAVE A EUREKA ALTIMA AND CANT CHANGE BELT
The hood will come off if you loosen two screws at the front on top of the hood by the brush bar bit that is slightly raised. Then there's a screw to the left hand side of the upright either below the hose or duster area. Once all screws are undone, the hood should pop off.
Dec 29, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Need to replace belt
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Dec 27, 2007 | Eureka WhirlWind 4381 Upright Vacuum
Vacuums Logo
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
