Question about Kenmore Sewing Machines
Old kenmore runs at choppy when trying to sew
I have an older kenmore sewing machine model #158.17741, when the pedal is depressed the needle moves at a choppy pace,
  • 46 Answers
Lubricate the machine. All metal against metal places. This should allow the machine to run smoother. This is an older machine and may need to be run full speed for a while to let it break free.
Posted on Jul 25, 2009
Singer model 750 - lights come on but motor won't run when pedal is depressed. I have a 2nd pedal which I tried also but still had the same results.
That appears to be an older mechanical machine. Bet it hasn't been cleaned and oiled in ages. Most likely it has seized due to old, dried oil. If this is the case, refrain from forcing the machine to operate as it could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Mar 10, 2017 | Singer Sewing Machines
Where are the oil ports on an old Kenmore 10 sewing machine #12511..thanks
If your older Kenmore is mechanical (not computerized), it probably can use a bit of oiling beyond what the manual recommends. Older machines frequently were pre-oiled at the factory, however, after many years, the oil tends to dry out and cause the mechanical parts to stick (the reason most older machines are frozen). Perhaps this link will be of help:
It was working now it seems to be frozen the needle part wont move
Feb 10, 2016 | Kenmore Sewing Machines
I have a Kenmore sewing machine, model # 385 15358600. The needle quit moving when I press the pedal. But, it will move if I turn it manually. How can I fix this?
that might indicate a new foot pedal is needed . these newer electronic ones fail where as the old carbon resistor type kept on working for decades
May 26, 2015 | Kenmore Sewing Machines
On my Kenmore sewing machine Model 1756 when I press the pedal the needle does not move. When I turn the hand wheel the needle does not move. any help out there? or is the machine done for
Disengage the sewing mechanism (like you are winding a bobbin)
If the motor runs fine that way then you have a machine that is frozen.
If that is the case take off the top, bottom, needle plate, needle bar and bobbin cover. Spray all moving parts down with Mean Green and let it sit for about an hour. After that blow it out with canned air.
See if there is any improvement. If so you just need to clean out all the old lubricants. Sometimes I take a hair dryer to loosen the sludge up.
Aug 26, 2010 | Kenmore Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
Machine wont' run or stitch
It is most likely the machine belt is slipping, re tension the belt and you should be fine. Also, just in case the needle has lost it's point change it and put in a new one just to be safe.
Jul 07, 2009 | White Sewing Sew Cute SC20 Mechanical...
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
108 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
